Results 1 to 5 of 5
Thread: need help with a VX head unit replacement
    VX S Pack Supercharged
    Aug 2008
    Default need help with a VX head unit replacement
    okay so ive been searching all morning for this and all i can find is broken links and bullshit on it
    all i need is a decent wiring diagram for a VX S and a tutorial/info on setting up the steering wheel controls... if this is possible to do myself?
    im pretty cluey with electrical but if the steering wheel controls are just a pain in the ass to do, id like to know because i wont even bother.
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    Accesories - Yellow
    Constant - Orange/White
    Illumination - Brown/White
    Earth - Black/White
    Power Antenna - Yellow/Red
    Front Left (+) - Tan
    Front Left (-) - Grey
    Front Right (+) - Light/Green
    Front Right (-) - Dark/Green
    Rear Left (+) - Brown/Black
    Rear Left (-) - Yellow/Blue
    Rear Right (+) - Blue/Orange
    Rear Right (-) - Blue/Black
    Remove the old stereo (covered a few times here, use coathanger wire) and unplug it. You can either chop the plug off and solder / tape your new stereo wires onto the car's loom or leave the plug on and just strip some insulation off each wire (not the copper conductor, just the insulation) with the aid of some wire strippers. Then solder / tape your new wires onto these. This way if you want to sell the car and keep your stereo all you need to do is chop off the new wires one at a time and tape the loom back up, then just plug the stock stereo back in.
    What i just do as far as mounting the new unit goes is just insert the cradle from the new unit (metal frame thing if you dont know) into the top of the hole left by the old stereo, it'll be a tight fit so just be patient, it DOES fit
    Then just pull the wiring through the cradle and plug the new unit in, slide it into the cradle untill it clips into place. You'll need a "snap in" universal pocket that just goes into the gap below the stereo, all done!
    Not sure about the steering wheel controls, havent done a VX i dont think......but they are a bit of a hassle so either leave it for the pros or forget about it
    150db in a commodore =
    Aug 2008
    hmmm i realy wana play mp3 cd's but i dont want to lose function of wheel controls... Tough choice.
    VK
    Jul 2004
    You can use a CAT to interface your steering wheel controls to an aftermarket headunit. Be willing to part with $150 though! I think JB Hifi stock them.
    Aug 2008
    okay thanks for the tip ill look into that. Like the dp btw lol
  1. VE Head unit replacement.. PLZ HELP
    By Lumina439 in forum Car Audio
    Last Post: 28-06-2011, 08:46 AM
  2. VT replacement head unit for iPhone conn
    By nickbedford in forum Car Audio
    Last Post: 30-07-2010, 07:48 AM
  3. Replacing VT head unit with BT ipod unit
    Last Post: 23-06-2009, 03:00 PM
  4. Vr Head replacement
    By VryNeat in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-03-2009, 09:41 PM
  5. Replacement head unit. VS caprice
    By coolngroovy in forum Car Audio
    Last Post: 01-06-2008, 09:42 PM
