Results 1 to 13 of 13
Thread: ute sub
    vr ute
    Jul 2009
    Default ute sub
    hey hows it going , just got a new sub for my vr ute today and got ute sub box with a
    12 "pioneer slim, it kinda sounds weird is it because the box is so small? and if i put a hole in the box like other sub boxes ive seen would the sound be better?
    CH Lancer
    Jul 2009
    What your talking about is a "port".
    Simply putting a hole in the box would make it sound HORRIBLE. It needs to be well planned out and will also require a larger box.
    Show us your current box plans please.
    Joe Bellissimo
    Shopping Secure - Car Audio Specialists
    www.shoppingsecure.com.au
    MSN/Email: sales@shoppingsecure.com.au
    vr ute
    Jul 2009
    vr ute
    Jul 2009
    Philthy's Avatar
    Philthy is offline That dent guy
    VS Berlina, XC AMS Project
    Aug 2005
    Define sounding "weird". I can't see an obvious problem from the components you have linked to.
    And by the way, gold star for providing good info about the gear you are using. A lot of people who ask questions on here could learn a thing or 2 from you.
    vr ute
    Jul 2009
    thanks lol
    well it kinda sounds like its muffled
    not a clean sound
    mayb because its right behind the seat?
    i moved the seat forwards and it still sounded the same tho
    Philthy's Avatar
    Aug 2005
    What do you have the LPF set to? It should be around 80-120Hz
    VZ SV6
    Oct 2008
    Victoria, Melbourne,Croydon
    I have heard that they can sound muffled becasue they are going straight into the seat and there is no where for the sound to go.
    Just out of curiousity how does that box fit behind the seat? how much room do you lose? possibly a picture?
    vr ute
    Jul 2009
    vr ute
    Jul 2009
    i was fiddling around with the sub just be for and found that the box has air coming out of the top when the subs going could the be the reason why the noise sounds different to other subs or would it have to do with being a slimline? and would a "port" help guide the air and make a better sound?
    Philthy's Avatar
    Aug 2005
    That could well be the problem. A sealed box is meant to be just that - sealed. It should have no air leaks whatsoever.
    Get the idea of a port out of your head for the time being. A ported box is completely different to a sealed one. To sound good it has to be matched pretty well perfectly to the sub that's in it, and would have to be a fair bit bigger than the one you have
    Bumming lifts, saving up.....
    Mar 2009
    Cairns White Rock
    I'm only having a guess, but I'd put it down the subs inability to move air,being so close to the seat, as the main problem as far as sound goes.
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    Ive installed a few of these and they dont sound too bad, for what they are. If there is air leaking out of the top of the box thats not good. Remove the box and unscrew the sub, look on the inside of the box where it is leaking and if you can see a gap etc, get some sealant and seal it up. Leaks definately cause subs to sound crap.
    150db in a commodore =
