Results 1 to 10 of 10
Thread: VY II Power Cable Issue
    raZel's Avatar
    raZel is offline The ride for life
    VY II Calais
    Feb 2005
    Default VY II Power Cable Issue
    Hey guys
    Hopefully a quick and easy one, ive done a few searches, couldn't really pinpoint what i wanted to know.
    Pretty much try to get the power cable through the fire wall on the drivers side of the car, REALLY having trouble getting it through the gromit. Is there an easy way to get it through? Or an easy way to make a hole without screwing up the other cables. Or should i just head for a new way through the fire wall, Photos or some descriptions of where or how it should be done would be great.
    Thanks Alot
    Skidney's Avatar
    Skidney is offline Utes do it better.
    VP UTE
    Sep 2009
    Adelaide CBD
    MattyC's Avatar
    MattyC is offline Just cruisin bro
    VT Calais 5L
    Jun 2009
    Quote Originally Posted by Skidney View Post
    stab a strewdriver through
    +1, take the peice of grommet out and make a hole in it and feed the cable through the hole
    Third Ride: 2002 VX SS 5.7L V8
    Second Ride: 1998 VT Calais 5L V8
    First Ride: 1999 VT S Series II
    VYMAD's Avatar
    VYMAD is offline SILVERFOX
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    ^^^^ Also put some rubber friendly grease on the grommet and your cable, such as Handy lube, thats the stuff that is used for tap o rings etc. I normally drill a hole in the grommet, though it has to be a fairly large hole as the rubber sort of springs back where the hole is.
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    Guys i think he's talking about putting the power cable through a grommit where theres already a wiring loom going through. If this is the case raZel, and the car is an auto, you can use the clutch cable grommit which is located next to the brake booster (on the right hand side of it when looking from the front of the car).
    Its an oval shaped grommit, just get a flat bladed screwdriver and prize it out, drill a hole in it and run you cable through, then insert the cable through the hole (may have to make a small hole in the carpet underlay etc) and then put the grommit back on.
    If its manual youve got a harder job, someone did say a while back there was another spot.....if youre still stuck i'll do a search and find the post.
    150db in a commodore =
    VYMAD's Avatar
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    Quote Originally Posted by holdenboy View Post
    Yes that's what he said "driver's side grommet" There's only one there, the clutch cable grommet, if he can't drill it as I could, then a sharp pointed instrument, or screwdriver will suffice, but a bit of that grease on the cable helps a lot. I have run two or three cables/wires through this grommet.
    raZel's Avatar
    VY II Calais
    Feb 2005
    Ok i will head out and give it a go now.. i will let you guys know how i go...
    Thanks alot for all the help much appreciated
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    vy ss sandman 5.7
    Feb 2009
    Up North Wa
    well if the clutch grommet doesnt work, then on the passenger side behind the glove box there is a hole. i used this for my amps power cable
    Vy ss sandman, bringing back the past!
    [CENTER]
    MattyC's Avatar
    VT Calais 5L
    Jun 2009
    Quote Originally Posted by ryan626 View Post
    +1. this is what i used
  1. power cable
    By markvr in forum Car Audio
    Last Post: 15-05-2009, 08:28 PM
  2. bonnet cable issue
    By Goon in forum VL Holden Commodore (1986 - 1988)
    Last Post: 12-09-2007, 10:31 AM
  3. VT amp power cable
    By danx in forum Car Audio
    Last Post: 15-07-2006, 05:21 PM
  4. power cable
    By matrix in forum Car Audio
    Last Post: 28-03-2006, 10:35 PM
  5. Power Cable
    By Brycestro in forum Car Audio
    Last Post: 25-03-2006, 02:26 PM
