How many amps can you pull through 4gauge cable??
Is 80A ok or is 60A the most.
What brand cable is it?
Ronald Reagan (1986)
some brands of cable pack on lots of shielding around the cable to make it look thicker than it is, true cables must be thick in the middle with copper wire..
if its proper it should handle 160 amps.
the brand is audioline the copper looks like its a good size
80A is fine for a 5m run of 4AWG cable.
150db in a commodore =
Where are you getting the 80A figure from, the fuse rating of the amp?
Anyway, why would you want 7-8m? where the hell are you mounting the amp?
I'd be more inclined to go with 2AWG for 7-8m, but 4AWG will still work OK.
