Results 1 to 9 of 9
Thread: Sub prooblem
    Vr acclaim
    Dec 2009
    Default Sub prooblem
    Well i just recently got a sybwoofer instelled with an amp obviously.
    well it all runs perfectly fine but then some times it randomly cuts in and out, i thought it may have been something to do with a weak wire joints so i pulled everything appart and all seems to be fine.
    and ideas?
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    We need model numbers of the sub and amp, or pictures.
    Is there a common part in a song (like heavy bass hit) or when you drive over a bump etc, when the sub cuts out?
    I assume you got it fitted by a proffesional? if so, take it back to them......after all it is their problem.
    150db in a commodore =
    VXHBD6's Avatar
    VXHBD6 is offline Get Hozed!!!
    VR Executive
    Jail Escaper Champion!
    Nov 2009
    South Australia
    Could be a bad earth? Double check that, I've heard bad earths cause problems like this pretty often. Good luck.
    Check It Out
    My 93' VR Executive
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    Could be anything... You need to troubleshoot a little yourself.
    If it cuts off long enough for you to get out of the car and look at the amp, see if the amp's power light is going off. See if there's a protection light coming on.
    Vr acclaim
    Dec 2009
    ok i found the problem
    its draining the shit outa my battery =]
    but i didnt think that my battery should run out when im driving?
    could it be a problem with the alternator or just a crappy battery?
    VXHBD6's Avatar
    VR Executive
    Nov 2009
    South Australia
    Yeah your battery should definately not be running flat while your driving. How old is the battery? And it actually does help if its a reliable brand of battery.
    Check It Out
    My 93' VR Executive
    AU II Falcon
    Apr 2010
    Goulburn
    cause some1 was rude and didnt say he fixed the problem , it was his earth. now its done up tight as a nuns you know what
    Vr acclaim
    Dec 2009
    AU II Falcon
    Apr 2010
    Goulburn
    shut up u, im bored
