Results 1 to 6 of 6
Thread: vn removing old head unit
    vn
    Dec 2009
    Post vn removing old head unit
    ok so i started taking out my old head unit poped plastic off around gear lever hand brake n the 1 around the headunit and pulled out the heater control but it only came out couple of inches then im stuck.
    1. does the heater controls hav to b fully removed not just poped out a few inches
    2, how do u access the screws on either side of the headunit
    vn
    Dec 2009
    Bumming lifts, saving up.....
    Mar 2009
    Cairns White Rock
    Why would you bump your post after 1/2 hour at 10:30PM on a saturday?
    Anyway, you have to remove the heater control unit completely, this mean disconeting the control rod, and the vacuem lines. You also have to remove the whole centre plastic section, not just the fascia as i'm assuming you've done. The screws will be located under the fuse panel, and also you'll have to flip down the glove box, should be 3 there aswell. Once you've removed that section, you'll se the how the mounting bracket is held into place..
    Good luck
    vn
    Dec 2009
    how do i get the heater control off ive been pulling as hard as i can i got the top connection off trying to get it off for hours
    VY SS
    Jun 2006
    Albany
    if you look around the foot rest you will see a white lever with a metal rod attached to it, if you move the heater control box while you are looking you should see it. you need to flick the white tab up so the metal rod will come free. hope that makes sense
    mrvdv is offline vanders
    VS Holden Commodore
    Apr 2008
    In A Suburb
    pull harder LOL
  1. help removing pioneer head unit
    By GLITRES in forum Car Audio
    Last Post: 18-03-2009, 11:54 AM
  2. removing factory wh head unit.
    By 02DUBH in forum General
    Last Post: 14-01-2009, 02:04 AM
  3. Removing Stock Head Unit
    By 10571z in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-11-2007, 10:44 AM
  4. Removing stock head unit
    By smyth in forum VY Holden Commodore (2002 - 2004)
    Last Post: 28-02-2006, 09:09 PM
  5. removing stock head unit in a VK
    By VRSS in forum Car Audio
    Last Post: 14-02-2006, 01:12 AM
Tags for this Thread
