Hey Guys,
I have a Alpine ida-x303 head unit in my commodore with front splits running off an amp, rear door speakers running off head unit and a sub running off its own amp. Had it installed about 7 months and all has been well.
Until I had my aircon fixed and the bloke had to take out the head unit and now I have this weird issue. When using radio everything works fine, all speakers plus sub run, but if I run my iPod instead only the rear speakers will work, no fronts no sub.
Basically, when I push the button on my head unit to run my iPod both amps lose power and only rear speakers work.
Sounds really strange to me IMO, does anyone have any ideas on what it could be?
Thanks in advance,
Scotty
its possible the aircon bloke has accidently sliced into the ipod cable. Get him to check it. Make sure you tell him that it only started to do this when the aircon was fixed. if that is what happened.
Might even be that he's connected the Antenna control to your remote wire instead of the proper turn-on wire?
Are the amps still on when your Ipod is playing?
150db in a commodore =
Possible...... But why would he touch the wiring loom other than to unplug it from the stereo and re plug it in? Could have ripped out the wiring loom from the car harness and incorrectly rewired it.
the iPod cable is fine, it still plays music from the iPod. The amps are totally off when you play through iPod.
If he changed any of the wiring in the loom I wouldn't think the amps would work on radio then.
I'm taking it down to a friend of mine now and see if he can help me.
Thanks for the responses guys, I'll keep you updated.
scotty
Well if he's connected your remote wire to the power antenna wire then there would only be power to that wire when the radio is on, any other source and the power is cut (as the antenna is not needed its meant to retract). So this would explain why radio works fine, but switching to another source causes the amps to turn off.
Yeah Luke i dont know what he would be playing around with that but you never know, just sounds likely to me with the symptoms given.
Good to hear it was an easy fix.
