Hi guys.....
Will standard 6x9's fit into the rear shelf of a VT? and do the 6x9's sit over the pre-drilled holes?
Thanks
Yes, you will need to remove the sections of metal that are tack welded into the pre-cut holes of the metal. You'll also need the grilles for the top of the parcel shelf, here they are:
http://www.aerpro.com.au/list.php?pc...+Grey&cat_sno=
1. Remove rear seat and parcel shelf
2. Remove metal sections
3. Screw in new speakers / wire them up
4. Cut holes in parcel shelf for grilles
5. Insert grilles into parcel shelf and re-install everything.
150db in a commodore =
Just be aware not to cut on the line in the shelf for the grilles. If you do the grilles will fall straight thru... Cut approx 1/2 inch inside this line and you will be fine.
cheers
Simon
Lets work as a TEAM and do it MY WAY!!
