Results 1 to 8 of 8
Thread: Amp?
    '94 Holden Calais VR V8
    Jan 2009
    Western Suburbs, Melb
    Exclamation Amp?
    I was at the local market over the weekend and came across a guy selling all kinds of different subs and what not. Found an Audiobahn ALUM12N Audiobahn :: Sub Woofers :: 12inch sub with 1000watt rms for $60 bucks brand new. Now my question is what sort of amp do i need to run this and the amp will not be running any other speakers either.
    thanks for your help in advance
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    Ohh 3-ohm sub, thats gonna suck. You are going to need an amp with about 700-800wrms at 4-ohm and 1400-1600wrms at 2-ohm. Something like this, Shopping Secure - Car Audio Specialists - SPL Dynamics S-2000D . Not cheap.
    Ronald Reagan (1986)
    Jan 2009
    Quote Originally Posted by acarmody View Post
    Ive heard of even purchasing a shneider 1450M but im not too sure with the brand dont know how good the they are from what ive heard they are only good for a year or two and then you have to end up buying a new amp
    VX Berlina
    Apr 2007
    Apparently Schneider aren't bad, not great but probably on par with most mainstream brands. But the 1450M won't make anywhere near enough power, it makes 1450wrms at 1-Ohm, so I would assume it makes 725wrms at 2-ohms, so I'd be thinking about 540wrms at 3-ohm.
    mintvr1994's Avatar
    mintvr1994 is offline get a real DIFF
    vr calais 3.8l
    Jan 2010
    chelsea
    u wont really need a very power full amp if its just one sub more amps u go the more likely ur sub will blow so around 600 or 700 watts would be fine
    VX Berlina
    Apr 2007
    Quote Originally Posted by mintvr1994 View Post
    Ummm how did you come up with that theory?? Its a 1000wrms sub, so therefore you would assume it will take 1000wrms all day long. Dosen't matter if that power is provided by 1 amp or 4 amps.
    Bumming lifts, saving up.....
    Mar 2009
    Cairns White Rock
    How come no one has asked the question of how you come to buy a 1000 watt RMS sub, new, for $60??
    And then consider going out and forking out over 1000 bucks on an amp for it?
    Oh and mintVR, what drugs are you smoking
    Luke0011 is offline Car Audio Installer
    VZ Berlina 2005
    Jan 2007
    1000wrms is the rated power. Meaning the voice coil will burn at 1000wrms
