Results 1 to 5 of 5
Thread: help with wiring 6x9's
    vy executive
    Jan 2010
    helena valley, perth
    Default help with wiring 6x9's
    hi all.
    i am installing 6x9's on the parcel shelf in my vy executive with stock h/u.
    i am happy with putting the wires under the trim and getting the speakers in their position.
    i am just confused about where do i conect the wires to at the head unit (there are so many little holes in the wiring behind the h/u).
    any help will be great.
    thanks
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    Well if youve ran new speaker wiring from the speakers to the head-unit you can just cut the correct wires (leave enough room so you can join them back up at a later date) at the plug behind the stereo, the wiring colours to look for are:
    Rear left speaker:
    (+) - Brown/Black Stripe
    (-) - Yellow/Blue Stripe
    Rear right speaker:
    (+) - Blue/Orange Stripe
    (-) - Blue/Black Stripe
    Usually i just run the new wires to the sill panel covers near the "B" pillar, and cut / join the wires to the existing wires before they head into the rear doors.
    150db in a commodore =
    Luke0011 is offline Car Audio Installer
    VZ Berlina 2005
    Jan 2007
    It is faster to run wires to the head unit than remove the sill panels on either side to connect into the rear doors.
    VYMAD's Avatar
    VYMAD is offline SILVERFOX
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    Quote Originally Posted by Luke0011 View Post
    I disagree, when I did mine, I tapped into them under the sill panels, too.
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    Yep i disagree too Luke, i dont totally remove the sill panels.....just undo the torx screw at the B pillar and the screws. This enables enough room for you to be able to access the loom and cut / solder new wiring from there.
    Wouldnt you have to remove the sill panel covers anyway to run new wiring to the head-unit?
    I do anyway, run the new wiring along with stock loom.
  1. [VIC] Kicker 400.1 Amp, Kicker 6x9's + Kicker Wiring Kit!
    By Dinwoodie in forum Parts And Other Items For Sale
    Last Post: 26-10-2009, 05:57 PM
  2. Do i need 6x9's
    By nicko in forum Car Audio
    Last Post: 19-11-2007, 09:46 AM
  3. do 6X9's fit
    By roger05 in forum Car Audio
    Last Post: 11-12-2006, 02:00 PM
  4. Amp and 6x9's with a sub?
    By Ace89 in forum Car Audio
    Last Post: 23-12-2005, 11:28 PM
  5. Replies: 9
    Last Post: 12-12-2005, 03:27 PM
