Ok, so I got a friend to help me clean up the wiring for my sub and amp.
Everything was fine until he decides to run a new control wire, and the RCA leads had one built in.
It was all good until when we turned it all on and the amp didn't fire up.
So he decides to connect the power wire to the control as well. The sub started making moving heaps and made a bang noise then he took the wire off.
So we scrapped that wire and connected my old control wire and replaced the RCA's, but now the front left channel on the H/U crackles/distorts really badly when its connected.
Ive tried running new wiring and a new speaker still crackles/distorts!
What could be the problem?
Also sorry about the life story![]()
So he bridged the REM and + terminals on the amp while the remote wire was still connected?
150db in a commodore =
Yeah and the H/U was on aswell, I was gonna say to disconnect it and turn it off first but it was too late.
Sounds like a head-unit problem.....take it out and have a smell, if it smells burnt then time for a new head-unit.....otherwise i cant figure out another solution, way too many variables![]()
It didn't smell at all, but the plastic covering on the control wire connection was melted a little.
Anyway well thanks for the help, I'm spewing tho. I normally just do the install myself, should've just cleaned the wires up myself.
Sounds like your mate just F***ed your HU
"I realize you were young and inexperienced at the time, but in hindsight you should have chosen your parents more wisely."
Tell me about it. Then he started saying he would lend me his other H/U, Never seen that happening at all.
Are your speakers running from the head unit or an amp? If running from the head unit, disconnect the distorting speaker and measure the DC voltage from ground (bare metal of chassis) to each speaker wire. They should both measure half of your supply, so around 6v with the car not running. If they measure anything else, the amplifier IC is toast.
You'd get the part from Pioneer spare parts, but you're probably better off getting them to fix it if you don't have much experience with soldering.
Ok I will give that a try when I get some time but i think its stuffed because it starts distorting/crackling when bass goes through the front left.
Also the speakers are running from the H/U.
The Amplifier IC as you said in your last post, Il try testing it and try to get a quote from pioneer to see if its worth getting fixed.
I said the IC costs $20. Labour would be $50-100 depending where you go which is still cheaper than all decent head unit.
