Page 1 of 3 123 LastLast
Results 1 to 25 of 54
Thread: Dual Sub question
    JonnyDe's Avatar
    JonnyDe is offline Donating Member
    VE SV6
    Jan 2010
    Ayr, North Queensland
    Default Dual Sub question
    I got a quick question for anyone who knows about subs and amps.
    I have just bought a VE Sv6. And i am planning to put two subs in the boot. I am going to make custon boxes to put one in each corner at the back and mount the amp/amps in the middle.
    Now heres the question, should i buy 1 big two channel amp, or two smaller mono amps?
    i know that i will need either a 2 channel LOC or get High Inputs on the amps.
    VS 97 Series II
    Oct 2007
    Whalan, N.S.W
    G'day mate
    any chance we could have some details of the subs? That way we could work something out for you.
    My new ride with some upgrades.
    www.teamfusion.info
    Head unit: Fusion CA-CD500 Front Speakers: Fusion PP-CM650
    Rear Speakers: FusionPP-FR6520 Subwoofer: Fusion PP-SW120 Amp For Front And Rear: Fusion PP-AM120040 Subwoofer Amp: Fusion PP-AM300010
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    Generally, one monoblock amp will be better.
    * Easier to install
    * Less wiring
    * More than likely cheaper
    But in saying that, if you want a nice symmetrical design in the boot then maybe two monoblock amps.
    Whatever you do, make sure the subs you buy are suited to the amps (impedance wise).
    150db in a commodore =
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    Just buy a mono with enough power to run both subs and make sure you buy the correct models to match the amp.
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    VP Exec
    Mar 2009
    Melbourne, bayswater
    Im running duel subs on a 2 channel amp
    Subs are pioneer 1200 watts each 450rms
    Amp is 500 watts.
    Also running another amp to my 6x9's (just bragging here )
    But if i had money to spend i would definitely buy 2 mono amps and hook up a sub to each.
    JonnyDe's Avatar
    VE SV6
    Jan 2010
    well, i dont have the subs yet, so im open to ideas. all up I dont want to spend over 700.
    im thinking dual 12's. I was thinking of just buying one really big Mono block and sticking it in the middle. but how do you wire two subs to it. Do i just run it in a parallel circuit?
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    $700 for 2 subs and a monoblock?
    Depending on what subs and what amp you get will depend on how they are wired. Lets just say you get 2x 12" 4 ohm DVC subs and a 1 ohm stable monoblock. This means you join the two +s and the two -s together from sub one, do the same with sub two and run the wires from each sub to the amp. This will give you a 1 ohm load for the amp.
    vz ss 5.7 ls1
    Aug 2009
    west
    Post 2 subs 1amp
    holdenboy this is my first post can you helpme out i have a sony sub 500wat 12 inch other sub sony 1500watt and a sony xm1502sx 2 channel amp can it run these woofers ? your help is appreciated:
    JonnyDe's Avatar
    VE SV6
    Jan 2010
    yeah, 700 all up is the max price. if i can get a good deal than that would be cool. Was looking at the Edge 12's from shopping secure. but open for surgestions.
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    OK well thats a tight budget for 2 12s and an amp to run them.
    Anyway, cant really go past the Pioneer's for value, heres some on Ryda as an example:
    Ryda Car Audio - Pioneer TS-W308D4 12" 1400W Subwoofer($178.85)
    So thats ~$350 for two 12s, they are available in either dual 4 or 2 ohm voice coils......so dual 4s will need a 1 ohm stable monoblock, dual 2s and you can do some nifty wiring to get 2 ohm.
    Kenwood 9014D, a favourite of mine for value, does over 900w at 1 ohm:
    Ryda Car Audio - Kenwood Car Audio KAC-9104D Car Amplifier($348.85)
    If you want to stick with Pioneer for the amp, then the only option with the money left over is the D8400M, only makes 600wrms but will still push those subs ok:
    Ryda Car Audio - Pioneer Car Audio GM-D8400M Car Amplifier($358.85)
    Then youve also got Joe's site (shopping secure), with more options again
    JonnyDe's Avatar
    VE SV6
    Jan 2010
    Well, if 700 is a bit low then i guess we can go to 1000.
    Its not gonna happen right now. will have to do some saving. I just wanted to know if it was better to go with dual amps or a mono block. SO far it seems that its best to go with a expensive mono block.
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    Yeah mate definitely a large single monoblock.....does the $700/$1000 include wiring and installation, or are you going to do it yourself?
    VY Berlina V6 / R31 Skyline
    Dec 2008
    Quote Originally Posted by VnPlayer View Post
    Amp is 500 watts.
    Your subs need 900wrms together running off a 500watt max amp?
    Quote Originally Posted by xVisions View Post
    driving without a license at the moment, My vl has beaten every single car I've street raced!!
  15. #15
    JonnyDe's Avatar
    VE SV6
    Jan 2010
    Il do it myself. I have already wired up one in my previous car. And im a 2nd year apprentice (at a holden dealer) so i have basic electrical knowledge.
    I just dont really know about sub and amp compatabilites and that stuff. And if rather go with something different. Soundstream, boston, Rockford fosgate, Vibe, Edge. That kinda stuff. cause everyone around my area has pioneer or alpine.
    i dont care too much if its not the loudest system, i just want a good quality one. But i do want dual's
  16. #16
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    Fair enough, i can understand you wanting something different but high quality.
    Look into Joe's gear then.....maybe look at the Vibe Slick 12s, single 4 ohm coils (so 2 ohm to the amp), Joe will be able to do you a better price also.
    As for an amp, if you want to stay with the same brand, the Vibe Slick A7 is suitable.
    So thats a total of $1300, but im sure Joe could get it close (or on) to the $1000 budget.
    Theres not much info on those EDGE subwoofers, so i cant say what amp would be suitable. Theyre probably 4ohm SVC so the same as the Vibe subs above. Anyway, an amp to suit based on my assumption would be the Option Audio OAX801, has 500wrms of output at 2 ohm so a little over.kill but thats fine.
    That would get you well under your $1000 budget, probably closer to $600-$650 if you twist his arm
  17. #17
    JonnyDe's Avatar
    VE SV6
    Jan 2010
    Sweet, I think il go with the Edges. I really like the orange subs. And saving a bit of cash is always good.
    Next month i become a third year apprentice. so i will actually be earning a living
    So around march sometime i will be making the order. Im sure within that time i can attempt at twisting Joe's arm
  18. #18
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    haha, yeah he'll take some $$$ off if you buy the subs and the amp from him (tell him i said he would haha).
  19. #19
    JonnyDe's Avatar
    VE SV6
    Jan 2010
    Just another quick question, Do you know if that Option Audio Amp has High Level speaker inputs. as I got a VE. I can always just buy a LOC. but thats another 100, and if i can get a better amp for 100 more than i think that would be better.
  20. #20
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    No, not by the look of it. Usually an amp with high level inputs will have a plug near the RCA inputs. That amp dosent.
    The Cache LOCs are good quality units, far better than the high level inputs on most (if not all) amps. Plus those LOCs have signal sense, so they turn on (and the amp too) when music is on, from his site:
    All of the Cache models feature a signal sense feature which allows them to activate as soon as you turn your head unit on. All the models also have a remote output which activates the amplifiers when the LOC is activated
    They also have a clipping (distortion) indicator....handy when your tuning the amp
  21. #21
    Timboy is offline Never been pulled over!
    2004 VZ Berlina
    Aug 2009
    So long story short (I'm gonna throw my query in here to make sure I don't start a new thread), I could run twin 12" type s alpines off a monoblock amp?
    [CENTER]Timboy
  22. #22
    Bumming lifts, saving up.....
    Mar 2009
    Cairns White Rock
    Quote Originally Posted by Timboy View Post
    Yes, you can, but you will need to find out the impedance levels of the amp, to determine the wiring configuration of the subs.
  23. #23
    2004 VZ Berlina
    Aug 2009
    Impedance?
    I'm running a cadence 1000w max and wanna power 2x12" Alpine Type S subs which are 350w each i think. Not sure if that's rms or max, but i'll check after I pick em up. If I get them and need a more powerful amp, I'll go buy one, but hoping that I don't have to do that
    [CENTER]Timboy
  24. #24
    Mar 2009
    Cairns White Rock
    If you give me the exact model number of the amp, i can draw you up a wiring diagram of how you will need to do it.
  25. #25
    2004 VZ Berlina
    Aug 2009
    FXA 1500 I think.
    Type S Alpine's, not sure exactly power or anything cause I don't have them yet :P
    [CENTER]Timboy
  1. Dual fuel VS statesman question!!
    By Thar in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-11-2009, 11:20 PM
  2. Dual mass flywheel question
    By goanna_38 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-08-2009, 05:08 PM
  3. Dual H/U DVD plus MP3....
    By Frandy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-09-2006, 07:23 PM
  4. VS dual air bag into VN
    By 89_VS_wagon in forum Projects
    Last Post: 27-02-2006, 09:10 AM
  5. VX Dual Fuel Injectors Question
    By Shounak in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-08-2005, 01:54 AM
