Anyone know of a good walkthrough for installing front and rear speakers in a VS? They are all 6" so no modification should be needed.
Not a walkthrough as such, but more of a guide to removing the door trims:
Removing Front Door Trim on VN - VS
From there just unscrew the speaker, either cut the old plug off and solder these wires to your new speakers, or make up a length of speaker wire using the speaker wiring / plugs that come with the new speakers and some spade terminals for the old plug.
Replacing the rears involves removing the rear seats (bottom section unclips, top section held in with bolts at the bottom) and parcel shelf (some random plastic screws etc - be careful with the shelf though as most are fragile). Then unscrew the speakers and wire the new ones the same way as above.
150db in a commodore =
Thanks, but I am a complete amateur at anything like this, probably need more detailed instructions with pictures. Just trying to save money by doing it myself.
Its not an easy task for an amateur i must say, theres a few steps than can be a little tricky.....and if not done properly you can break things
Its up to you though, if you take your time and be gentle with things.....then you should be able to do it.
