Results 1 to 4 of 4
Thread: securing tweeters in VZ dash
    VZ Acclaim
    Jan 2010
    Default securing tweeters in VZ dash
    hey all.
    im about to install my setup of alpine X and was just wondering how to hold the tweeters in place in the dash.
    any help or tips would be greatly appreciated.
    cheers
    VK
    Jul 2004
    I found it best to use the brackets that the original tweeters were mounted on. You might need to modify them slightly depending on the mounting points of your new tweeters.
    VZ Acclaim
    Jan 2010
    VesperZ's Avatar
    VesperZ is offline 2005 Holden VZ Berlina
    VZ Berlina
    Jul 2009
    Sydney, NSW
    Quote Originally Posted by vz05 boar View Post
    thanks yeah i was thinking i might have to do that
    Hey,
    I put my Type R splits in the original tweeter location under the dash. Basically there is one screw (from memory) holding in the top part of the dash (be gentle when you remove this as it can easily snap). You'll have to remove the side vent covers first though to get access to it (from memory thats 3 screws). Then you'll need to unscrew and unclip the wiring from the original tweeters. I'm pretty sure the brackets holding in your tweeters is held by 1 screw. Once you get your tweeters out, dismantle the bracket from the original tweeter and I screwed the bracket to the back of my new tweeters. It's a bit of a struggle to get the new tweeters in, but by twisting it the right way they only just went in. Pretty happy with the install, it's hidden and it sounds pretty good too. Yes there are more ideal locations for tweeters but in my opinion your looking at either drilling a hole in your door trim or custom fabricating it somewhere which to me looks chatty anyway.
    "Nonsense, this is the kind of coverings what we humans wear at this period of time. I'm quite sure of it."
    See my ride here
  1. How to actually mount tweeters in VP dash?
    By arrow224 in forum Car Audio
    Last Post: 29-12-2009, 08:23 PM
  2. VE Dash Tweeters
    By V8s and beer in forum VE Holden Commodore (2006 - ?)
    Last Post: 29-12-2009, 12:32 PM
  3. How to remove tweeters from dash. (VT)
    By lil_oneblue in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-08-2009, 08:59 AM
  4. Securing Sub Box
    By dawg in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-11-2007, 05:07 PM
  5. Tweeters in VS Calais Dash
    By ICUBYE in forum Car Audio
    Last Post: 18-08-2006, 01:04 AM
