Results 1 to 21 of 21
Thread: VZ stereo HELP please
    VZ
    Feb 2010
    Default VZ stereo HELP please
    Hi Everyone,
    New here & to commodores.
    I'm trying to put my stereo into my VZ wagon and having some issues. It fits great but the wiring is confusing me.
    I've cut the factory plug off so i've got all the wires there ready to join to my stereo's loom. ( jvc headunit )
    as posted on here::
    VN - VZ
    Accesories - Yellow
    Constant - Orange/White ( CANT FIND THIS ONE!! )
    Illumination - Brown/White
    Earth - Black/White
    12V OUTPUT - Yellow/Red
    Radio Mute - Yellow/Black (VT onwards)
    Antenna up - White (VR onwards)
    Antenna down - Blue (VR onwards)
    Illumination OUTPUT - Grey (VT onwards)
    I may have blown my fuse when i touched a wire by mistake cause now i can't get 12v out of the accessories either. ( which i notice stays on even after you take the key out of the ign for a while )
    Some help would be greatly appreciated!!
    cheers.
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    Umm I'm not reading this right. Whats the problem? Blown fuse? Change the fuse.
    And the car will keep giving accessories power until you open the drivers door or the time limit is hit.
    Ronald Reagan (1986)
    VZ
    Feb 2010
    1. Is there a 2nd fuse box? I don't see one for the acc / stereo in the box under the bonnet....
    2. Need someone to explain my lack of constant power wire.
    VX Berlina
    Apr 2007
    Quote Originally Posted by snicko View Post
    1. Under the steering column.
    2. Hmmm don't know, just make a new one. Use any at the back of the fuse box.
    VZ
    Feb 2010
    1. thanks i will go out with my torch and try to locate this fuse box again ( i know there was one there in a mates VT but didn't see it in the VZ.
    2. That is possible. Thanks.
    VX Berlina
    Apr 2007
    Just remember if you make a new constant power, to put a fuse in it.
    Luke0011 is offline Car Audio Installer
    VZ Berlina 2005
    Jan 2007
    Welcome to the forums, you probably have blown the fuse when you cut the wires. Pull the fuse panel down under the steering column and check the radio and cigarette lighter fuses. Next time just cut the wires one at a time and try not to let the wires touch.
    VX Berlina
    Apr 2007
    But Luke0011 then where we get to see cool light shows. Like the time I undid the positive battery terminal with my spanner, and touched the handle to the chassis.
    VZ
    Feb 2010
    ok still not finding a fuse panel under the steering column.... somewhere else on the vz?
    VZ
    Feb 2010
    VZ Berlina 2005
    Jan 2007
    Haha, ive done that a few times, lol. There is also a fuse box next to the battery, remove the cover and check the fuses there.
    VX Berlina
    Apr 2007
    A picture for ya. You didn't pull down the cover did you. LOL.
    Just get you hand between the cover and steering column, pull towards seats and down.
    Attached Thumbnails Attached Thumbnails VZ stereo HELP please-vz-fuse-panel.jpg
    VZ
    Feb 2010
    Quote Originally Posted by acarmody View Post
    haha Thanks. All done now. I still need to run a constant power wire tomorrow but the stereo is working great just running on the acc.
    Thnx again.
    VYII Acclaim
    Jun 2008
    Largs Bay, Adelaide, S.A
    According to the attached wiring diagram, look for 'Orange/Black' (constant 12v). Also check the fuse, you may have blown it.
  15. #15
    VZ
    Feb 2010
    Quote Originally Posted by scozz76 View Post
    Click image for larger version.
Name:	Audio System.jpg
    I know i have 2x orange blacks which both had no power when i tested them last night. If they're on a separate fuse to the radio then that could be why. I'll check the fuse box and hopefully get power to one of those O-bK's tomorrow.
    VX Berlina
    Apr 2007
    So do you lose all your settings when you turn the car off? Because that would suck.
  17. #17
    VZ
    Feb 2010
    yeah but i knew that when i couldn't hook up constant power. I will fix that problem tomorrow and wire in the dvd monitor too.
  18. #18
    TMM's Avatar
    TMM
    TMM is offline OEM+
    VY Berlina S2
    Jun 2008
    VIC
    That's why you remove the ground terminal first
  19. #19
    06vzcalais is offline Donating Member
    Aug 2009
    i went to autobarn and bought an adaptor loom (no cutting of wires. plug and play. i can now refit the factory unit when i sell the car
    just a hint for next time
  20. #20
    VZ
    Feb 2010
    yeah i'm pretty sure if i ever sell this the person buying will be happy with a better than factory stereo. Can't believe how much better it sounds now even through stock speakers.
  21. #21
    VX Berlina
    Apr 2007
    Quote Originally Posted by TMM View Post
    Yes, yes, I know, my bad. I was actually doing UP the nut, and I had like 20 minutes to drive 30 minutes to work, I was just chucking everything back together.
  1. VE SV6 Stereo Help
    By MattB-05 in forum Car Audio
    Last Post: 04-02-2009, 01:45 PM
  2. need help with stereo
    By trumpstar in forum Car Audio
    Last Post: 12-01-2009, 11:13 PM
  3. stereo
    By CALAIS 6 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 21-08-2005, 11:31 PM
  4. VY Stereo
    By wheelz_27 in forum Car Audio
    Last Post: 20-06-2005, 08:15 PM
