Results 1 to 9 of 9
Thread: am i correct
    VN Berlina 3.8
    Apr 2005
    Default am i correct
    i need to test my deck to see if its working. if io join a wire form the red terminla and touch and it on the postive terminal on the battery and the black to the negative should it come on
    rattattack1313 Guest
    VT Executive S2
    Jun 2005
    Morayfield - QLD
    Post
    Isn’t there an accessories wire you would need to connect also so that it actually turns on?
    VT Commodore
    May 2005
    Default re
    If your head unit has both constant + and accessories +, both will have to be connected to 12v supply for head unit to work.
    Tasmaniak's Avatar
    Tasmaniak is offline Not a valid input....
    car
    Apr 2005
    Yup, both positive wires must be connected to the battery post to test, like Rattatack said...put a fuse in there incase the HU is stuffed and decides to short the battery out
    Majesticknights's Avatar
    Majesticknights is offline The Dark Prince
    VL HDT Calais Wagon Brock 346 stroker
    Jun 2005
    Montrose, Vic
    if u dont already know the constant power or Memory lead is yellow to the + side, ignition is red to the + side, earth is Black to the - side and if u wanna get it to light up then the illumination wire is orange with a white stripe to the + side. these are the usual situation anyhow and if u already knew then sorry for treating u like a child
    resyo Guest
    Be aware that the common wiring colours available on this site and SC are not always the same for every VN. For example, if I remember correctly, my VN Calais had orange and white as constant and had no illumination wire (which doesn't bother me).
    You can test each one of them with a test light or multimeter. Ensure all fuses are ok and not blown. When you register a voltage accross the following, you have;
    Constant - Ignition off - Negative to metal chassis, Positive to one of the wires.
    Accesories - Acc to on - Negative to metal chassis, Positive to a different wire.
    Illumination - Headlights/Dash lights on - Negative to metal chassis, Positive to a different wire again.
    If you can't work out your ground wire (should be black), you'll need a multimeter to measure resistance between the wires and the chassis, or simply run another eath.
    [Edit] its pretty pathetic this site wont let you say streetcommod0res
    VN Berlina 3.8
    May 2005
    wikid 1 question though. i have a wire that was running from the dash to the postitve terminal on the amp. tha yellow wire which is coming from the rca is merging with this as it must get it power from here(constant power i think). after they merge i cut the redwire off to the amp so it should be still getting power should it although i cut the red wir off(after the merge). also power is coming to the deck becuse you can make the cd come in and out however the display will not light up any suggestions
    VN Berlina 3.8
    Apr 2005
    cheers guys i figured it out
  1. 1 KW = 1.3 HP... correct???
    By walesy in forum The Pub
    Last Post: 15-01-2007, 08:16 PM
  2. Correct cable?
    By desruction in forum Car Audio
    Last Post: 04-01-2006, 06:09 PM
  3. no (correct) speedo
    By Boonz in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-12-2005, 01:39 AM
  4. Politically Correct....
    By rattattack1313 in forum Jokes/Humour
    Last Post: 02-08-2005, 12:12 AM
  5. Is this Correct ?
    By Darkwander in forum Car Audio
    Last Post: 13-02-2005, 09:41 PM
