Originally Posted by
VZ-Rob
As I understand it the SPS600 is a 2way co-axial ?
I think i added a "c" at the end some how and came up with the Type S components when i searched.Searching again confirms they are the coaxial version.Must have been late for me lol.
In that case, my previous reccomendation for bridging the amp should be dissregarded.
OP, you have 2 options.Full pass, or High pass.Me personally i would go the high pass option, you will loose some of your low end response, but that shouldnt really be an issue.It depends on what you want,
Full range- speakers are being sent the entire sound frequecny spectrum.Meaning they will play more frequencies within their response.However, they will be limited to how loud they can play, because they are trying to reproduce low fq sounds (bass) which they are not designed for.
High Pass- Speakers will recieve the sound frequency spectrum above a certain frequency.It's up to you where you set the cut off.I'd start at around 60hz, and work my way up form there.Meaning that the speakers do not play any low fq sound, below the set point.Speakers can therefore play louder.
