Results 1 to 19 of 19
Thread: Dual 12" Kicker Comp subs in kicker ported box - WHATS A GOOD CHEAP AMP I CAN GET 4IT
    Jordzz's Avatar
    Jordzz is offline VL Calais 5 Spd ### yea
    VL Calais 5spd VT S 5spd VX Berlina VP 5spd VS Cal
    Jun 2009
    Default Dual 12" Kicker Comp subs in kicker ported box - WHATS A GOOD CHEAP AMP I CAN GET 4IT
    as title says
    Im about to pick up these "Dual 12" Kicker Comp subs in kicker ported box"
    and I was just wondering what a good cheap amp would go good with it as I really dont have a clue what I should be looking for.
    Never Late with a 3.8
    Bumming lifts, saving up.....
    Mar 2009
    Cairns White Rock
    The more information you give us, the more we can give you.If we know the model number, we can look at the impedance levels of the subs, then once we know your budget, we can begin making reccomendations for you.
    VY Berlina V6 / R31 Skyline
    Dec 2008
    ^^^^ He's on the money mate.. if you can tell us which subs they are or the specs of the subs we can give you an idea of an amp/wiring.
    Cheers.
    Quote Originally Posted by xVisions View Post
    driving without a license at the moment, My vl has beaten every single car I've street raced!!
    ethann's Avatar
    ethann is offline Low And Luxurious!
    '11 WRX, '73 Stingray, Lifted/Locked GQ.
    Dec 2009
    Newcastle, NSW.
    Mar 2009
    Cairns White Rock
    Quote Originally Posted by ethann View Post
    From memory there around the 400rms each I think?
    What we are more after is the impedance levels and the amount of coils, rather than their power output.
    nathanVY's Avatar
    nathanVY is offline need boost...
    03 VY Calais, 99 VT Equipe
    Dec 2009
    Geelong, VIC
    ethann's Avatar
    Dec 2009
    Newcastle, NSW.
    Quote Originally Posted by nathanwright View Post
    whatever you do dont get a kicker amp, mine always overheats.
    Haven't had any dramas with my KX600.1
    And its the older model..
    Mar 2009
    Cairns White Rock
    That's a pretty silly and useless comment to make.Amp's don't overheat, unless they are being miss treated , or miss used.Your amp is most likely underpowered for it's duties, and you are putting it under too much stress.
    nathanVY's Avatar
    Dec 2009
    Geelong, VIC
    Quote Originally Posted by HoldenCommodoreVP View Post
    it's running 2 6x9s and a sub. if anything is too much for it, its the sub. I had a less powerful one but swapped with a mate cos his amp couldnt run the sub (that I have now) at all. The sub could be damaged as well.
    I thought amps could and did overheat, thanks for clearing that up for me.
    Dec 2008
    Hold up..
    your running 2 6x9 inch speakers and a sub off a 600wrms monoblock??
    Your problem could start there mate.
    CH Lancer
    Jul 2009
    Quote Originally Posted by Jordzz View Post
    as title says
    I'm pretty sure the ones your talking about are 150 rms each and single 4 ohm. Take a picture for us and we can work out the rest.
    Joe Bellissimo
    Shopping Secure - Car Audio Specialists
    www.shoppingsecure.com.au
    MSN/Email: sales@shoppingsecure.com.au
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    What model amp are you talking about?
    Ronald Reagan (1986)
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    Anyway, back to the topic guys......if they are 4 ohm single voice coil then you will need an amp that produces 300-500wrms at 2 ohms, if depends on how much you want to spend, heres a few examples:
    Clarion 400wrms @ 2 ohm monoblock, approx. $200.
    Kenwood 500wrms @ 2 ohm monoblock, approx. $220.
    Kicker 300wrms & 2 ohm monoblock, approx $250.
    There will be little difference in sound between those three options, only price, build quality and cosmetics will change.
    150db in a commodore =
    Jordzz's Avatar
    Jun 2009
    Im probs looking for a sub priced really no more then the 200 mark
    Heres a pic of the subs along with the specs hope this helps
    Subwoofer Specifications:
    12" Comp C12 Subwoofers
    Power Handling:
    Peak: 600 watts (300 Each)
    RMS: 300 watts (150 Each)
    Impedance: Dual 2 Ohms
    Oversized ports with flared ends for efficient air flow and no noise
    ISD (Inverted Structural Design)
    Cone's back bracing eliminates distortion
    Nickel plated push terminals
    Frequency response: 27-500 Hz
    Sensitivity: 89 dB
    Attached Thumbnails Attached Thumbnails Dual 12" Kicker Comp subs in kicker ported box - WHATS A GOOD CHEAP AMP I CAN GET 4IT-kickercompsubs.jpg
  15. #15
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    Hmm, well after doing abit of research and going off those specs it seems each sub is 2 ohm, so thats a final impedance of either 1 or 4 ohms.
    This gives you a few options as far as an amp goes........so you only want to spend $200 on an amp?
    Heres a few suggestions that would be suitable:
    Jaycar 1 x 500wrms amp, RRP $219.
    Clarion 1 x 320wrms amp, Ryda Price $221.05.
    Kenwood 1 x 500wrms amp "Clearance" from Ryda $198.85.
  16. #16
    Jordzz's Avatar
    Jun 2009
  17. #17
    Mar 2009
    Cairns White Rock
    My vote goes to the Jaycar amp.For the money your spending, sound quality, even build quality, shouldn't even be on the cards.Raw power, and bang for you buck is what you need.When you say you want a good amp, well for that type of money, good to me is ample power, and a warranty
  18. #18
    2Com's Avatar
    2Com is offline $$$ talks Bullshit walks
    VZ
    Jul 2006
    A friend of mine was running these same kickers on a Kenwood 1000w Monoblock, it makes 500wrms and it runs these subs very well.
    The amp brand new is $200 and the Part number is KAC-8104D.
    Soundmaster Car Audio - ($198) Kenwood KAC-8104D Amplifier KAC8104D
  19. #19
    vt ss 5ltr
    Feb 2010
    narre warren
    ive got the kicker 400rms *i think it is* monoblock running my comps and i got told thats the right amp for them but kicker amps are expensive and other brands will do the same job
  1. Kicker C12 (Dual Ported) subwoofer Box design for VE
    By bigdavepink in forum VE Holden Commodore (2006 - ?)
    Last Post: 13-03-2010, 08:56 PM
  2. Buying dual kicker cvr subs
    By J3zza in forum Car Audio
    Last Post: 25-10-2009, 12:02 AM
  3. [VIC] 2x12" kicker cvr subs for sale.$350.cheap!!
    By v8_stato in forum Parts And Other Items For Sale
    Last Post: 08-05-2009, 06:01 PM
  4. 2 12" kicker subs
    By badger__rox in forum Car Audio
    Last Post: 29-03-2007, 02:19 PM
  5. Kicker Solo Baric 18" & Kicker Equalizer
    By sbkvp in forum Car Audio
    Last Post: 05-12-2004, 07:05 PM
