You can wire it as you said, but as you adjust the rear speaker level (with fader) you'll be adjusting the sub too. It just means you'll have to use the EQ to adjust your bass levels rather than a dedicated sub level control. So make sure you set the high pass filter on the amps for all the speakers so your bass adjustment doesn't hit them as well.
LinkBack URL
About LinkBacks
