Results 1 to 19 of 19
Thread: Audio System for my VS
    2000 VT S-Pack II
    Dec 2009
    SE Queensland
    Smile Audio System for my VS
    Alrighty,
    Been trying to learn more about audio set-up for cars and have gotten some help from people on the forums (thanks guys). I have been looking at car audio on the web for a bit and have found WOW to be a good place for some cheap stuff to help my sound, especially since i'm working on a budget.
    Below is what I am planing to add onto my stock commy vs within the next week or so.
    All prices are from the 'WOW Sight N Sound' website.
    $ 90 SONY CDXGT180 CD/TUNER 52Wx4 AUX IN 1 x RCA DETACH FACE Head Unit
    $ 80 2 x 6.5" 260 watt 3-way speakers
    $ 60 Fusion Reactor 12" Single Voice Sub-woofer
    $ 35 Sub-woofer box
    $100 Boss Audio Mono Block AMP 1000 watts amp
    ____
    $365 TOTAL
    ____
    I will go and listen to it before purchase, but budget wise this is mint and will sound alot better than the standard sound system of the vs lol
    Few questions about the items:
    2 x 6.5" speakers - I know that 6" go in easy, I assumed the 6.5" will go in well?
    Fusion Reactor Sub - The site had both 12" Fusion 'reactor' and 12" fusion 'encounter'. From what i see on the Fusion Website, the reactors are meant to be better and cost more than the encounters, yet on WOW the encounter is $20 less than the encounter... that make sense?
    Boss Audio Amp - Seems to be a pretty good buy since it is only $100 atm and is usually $170! hopefully this system gets good write ups?
    Thanks again for the help/advice and putting up with a car audio virgin lol
    PS: anyone know what WOW will charge me for installation on this? I'll phone up tomorrow anyways and find out I guess.
    PSS: Was also thinking of getting sub facing into the car and just pull down the centre back seat, hopefully they have enough wiring though so i can move it the other way round if i want too aswell.
    thanks
    Matt
    2Com's Avatar
    2Com is offline $$$ talks Bullshit walks
    VZ
    Jul 2006
    the 6.5" speakers will fit into the standard 6" speaker hole with slight modification/cutting of the plastic
    if you are good with your hands you should be able to install the whole system yourself if you take your time. give it a day or so.
    2000 VT S-Pack II
    Dec 2009
    SE Queensland
    Quote Originally Posted by 2Com View Post
    that's good to know, thanks bro. hopefully this system will sound well and work well all together
    VZ Executive
    Nov 2008
    stay away from Boss they are complete rubbish
    look for something from a reputable brand instead to save yourself a whole lot of grief
    VS 97 Series II
    Oct 2007
    Whalan, N.S.W
    Quote Originally Posted by 2LOUD2OLD View Post
    ^---- I agree, and those amps have been known to start fires.... Plus alot of people get the Strathfield Boss Audio amps confused with the American branded Boss Audio. If you can see the amp listed on the website link, it's an ok honest purchase. If the one you're talking about has a model number starting with the letters "BA", it's not in anyway connected to the American branded Boss products.
    JSTCOZ, do you intend to put the three ways in the front?? Having three ways in the front would be way to bright. Try and find a set of two way splits, that way you will get a much better sound!
    My new ride with some upgrades.
    www.teamfusion.info
    Head unit: Fusion CA-CD500 Front Speakers: Fusion PP-CM650
    Rear Speakers: FusionPP-FR6520 Subwoofer: Fusion PP-SW120 Amp For Front And Rear: Fusion PP-AM120040 Subwoofer Amp: Fusion PP-AM300010
    CH Lancer
    Jul 2009
    If you are on a budget and are looking for a cheap and reliable subwoofer solution I will throw a couple of my solutions in:
    Shopping Secure - Car Audio Specialists - FLI Trap 12" Active
    Shopping Secure - Car Audio Specialists - EDGE ED Bass 12 ACTIVE
    Both of those are built well and include decent subs, great boxes, a build in amplifier and a wiring kit to power it. It will cost a bit more but I know those of those packages have been designed to work effectively and reliably.
    I've also got some cheap speakers which I think are great value for money: Shopping Secure - Car Audio Specialists - EDGE ED206
    That said, I think you are better off saving your money on the rears and only upgrading the fronts. My customers rave about these: Shopping Secure - Car Audio Specialists - FLI INTEGRATOR COMP 6 (I agree with vg-ute-mad)
    Thats my imput, btw I'm the owner of that website so I can answer any questions you might have about the gear
    Joe Bellissimo
    www.shoppingsecure.com.au
    MSN/Email: sales@shoppingsecure.com.au
    2000 VT S-Pack II
    Dec 2009
    SE Queensland
    Quote Originally Posted by Joe Bellissimo View Post
    All of these prices are wayy too high for me sorry. I'm not looking for an awesopme system, im not overly picky on sound, i just want some cheap speakers that get good write ups (fusions) and that are an improvement on a standard system. I was hoping to pay no more than $450 in total for everything.
    2000 VT S-Pack II
    Dec 2009
    SE Queensland
    Quote Originally Posted by Vg-ute-mad View Post
    Yeah they have BA at the front, but they are usually $170 and are $100, so i assumed they were good. guess not...
    2000 VT S-Pack II
    Dec 2009
    SE Queensland
    maybe i can get a
    KENWOOD 2CH AMP, 350W MAX, 60W X 2 RMS AMP for $140 instead of the Boss Audio then?
    Does the AMPs Watt level, need to be equal too or higher than the max Watt output of all the other things you have? Like sub and speakers and head unit?
    My mate says it does... that true?
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    You need to look at the speakers RMS power handling, then look at amps with around the same RMS output per channel.
    In saying that, a pair of 60wrms speakers will run fine off a head-unit. You just wont get the full potential from the speakers, as they arent getting the optimum power they require.
    150db in a commodore =
    CH Lancer
    Jul 2009
    Quote Originally Posted by JSTCOZ View Post
    Mate the total came to $500 and I will happily discount to $450 if required... I think the suggestion I've given you offers exceptional value for money but if you don't feel the same way as I do then thats fine. Just thought I would clear that up for you mate.
    Joe Bellissimo
    2000 VT S-Pack II
    Dec 2009
    SE Queensland
    Yeah, sorry I didn't mean to offend. Just not having alot of money and income at the moment. And that's an online store yes? rather a store i can drive to as well. much appreciated for your help though. maybe if WOW doesnt go well ill have a look again at what youve suggested .
    Bumming lifts, saving up.....
    Mar 2009
    Cairns White Rock
    Before you go out and buy all this stuff, give the money to someone else so you can't spend it, come back, sit down, and start again lol.
    You can't just grab any amp, and expect it to run any sub and so forth.I didn't have time to look, but does that head unit even have a sub out? otherwise it's going to be shit house to tune without it.
    I suggest you take you time, you seem like your in a bit of a rush to go out and buy stuff.I woudn't be concerned that Joe's store is online, at least it is a dedicated car audio store.Wow sells everything from electric toothbrushes to fungus cream.
    CH Lancer
    Jul 2009
    No worries mate. I do look forward to dealing with you in future though. I wish you luck and hope they look after you. I started this business because I used to be in your situation and I was really unhappy with the service I got from my local big shops. I hope your experience is better than mine was!
    Joe Bellissimo
  15. #15
    2000 VT S-Pack II
    Dec 2009
    SE Queensland
    Just rang up wow and they were gunna charge me $850 with labor charges.... i think i need to rethink.
    'Joe Bellissimo' how much does it cost with postage and what would installation prices be looking around? EDIT: Remembered i have a friend that installs audio in cars for a living... lol
    Also, I am now easing up abit and won't rush into buying speakers. Joe I am looking over your site too, you're right that the prices and quality are better, just took me a bit fo calming down to realise it.
    thank you
  16. #16
    CH Lancer
    Jul 2009
    Thats cool mate. To be honest I would be trying to offer free shipping but it would depend where you live. PM me your postcode and I will look into it.
    Thanks for considering the products on my site mate! I really hope as you progress through your research that you will find me gear to be what your looking for!
    Joe Bellissimo
  17. #17
    wraith's Avatar
    wraith is offline Hand over the dog bikkies
    '95 VR Series II
    Sep 2008
    Demonicaland
    Fusion has packs which come with everything to get sub-woofers going. Generally cost effective as it comes with everything (the sub, amp and all associated wiring). If your on a budget option audio 6.5" in the doors and parcel shelf will be ok. Sony has decent head units as do JVC.
  18. #18
    VS Executive V6
    Nov 2008
    QLD, Australia
    hey mate, i recommend buying/installing one component at a time, eg. headunit first, then front speakers, then rear speakers etc. i did this in my old car (my first audio install) and it helped me to get a better understanding of what each component did, like i found out how much of a difference a headunit can make to sound quality.
    also, in my system i found that its worth spending a bit more money to get a good quality, more powerful amp.
    just my 2 cents, but good luck with the install and everything
    Drop clutches, not bombs.
  19. #19
    VS 97 Series II
    Oct 2007
    Whalan, N.S.W
    Well said!!! I counldn't agree more!!!!
    www.teamfusion.info
  1. VX Audio system
    By VX21 in forum Car Audio
    Last Post: 11-07-2009, 11:43 PM
  2. VS Audio system
    By HamaTime™ in forum Car Audio
    Last Post: 28-02-2009, 05:32 PM
  3. Vz SS Audio System Help help help
    By Jack Parks in forum Car Audio
    Last Post: 19-01-2009, 11:53 PM
  4. Audio System
    By wes_v8 in forum Car Audio
    Last Post: 14-08-2006, 07:06 PM
  5. Audio System
    By Fitty in forum Car Audio
    Last Post: 04-09-2005, 05:05 PM
Tags for this Thread
