Hi guys can someone please give me all the wiring colour meanings including wheel controls on my 02 vxss so i can install my clarion dvd?cd player asap dont realy want to chase up adaptors as i live in remote area i can find diagram for vt but not sure if they the same and it dont say ne thing about wheel controls any help would b greatly appreciated
you cant just wire up the steering wheel remote buttons from a VT/VX to a aftermarket stereo. VT/VX controls use a single wire that works by resistance. You will need an adapter that interprets the different resistance values, and converts it to an IR signal that your stereo can understand.
im pritty sure the wires from vt - vx are the same i used to work at strathfield ill see if i can remember them
Orange = +12v
Yellow = Accessorys
Yellow/Red = Electric Antenna
Green+Light Green = Front Right
Tan+Grey = Front Left
Blue/Orange+Blue/Black = Rear Right
Brown/Black+Yellow/blue = Rear Left
Black/White = Ground
Brown/White is Illumination is used if the display is too bright for you wire it up to ur aftermarket unit and when you turn lights on it dims the display, Only if your head unit has Illumination Input
The left over wires would be a phone kit mute and steering controls i think yellow/black is mute and the rest is wheel control i cant remember 100%
THANKS ALOT could you tell me which wire to leave out then and if this is correct wiring sequence please
accessor 12v=yellow
battery 12v=orange/white
dimmer in 12v=brown/white
ground=black/white
constant 12v output=yellow/red
FL+=TAN
FL-=GREY
FR+=LIGHT GREEN
FR-=DARK GREEN
RL+=BROWN/BLACK
RL-=YELLOW/BLUE
RR+=BLUE/ORANGE
RR-=BLUE/BLACK
PHONE MUTE=YELLOW/BLACK
ANTENNA DOWN=BLUE
ANTENNA UP=WHITE
DIMMER OUT=GREY
DOESNT SAY NE THING ABOUT STEERING WHEEL FEED?
HELP WOULD BE APPRECIATED
half of that is not right don't know where you found that from haha, ant up and ant down is not right its just one wire witch is the yellow/red, there's no dimmer in and out its only a out which is the brown/white, i think its either the white or blue for steering.
What sort of steering wheel control module do you have? because u cant run straight from factory wire to aftermarket unit and usually the module has instructions for your car because you need to program it up
Accesories - Yellow
Constant - Orange/White
Illumination - Brown/White
Earth - Black/White
Power Antenna - Yellow/Red
Radio Mute - Yellow/Black (VT onwards)
Speakers
Front Left (+) - Tan
Front Left (-) - Grey
Front Right (+) - Light/Green
Front Right (-) - Dark/Green
Rear Left (+) - Brown/Black
Rear Left (-) - Yellow/Blue
Rear Right (+) - Blue/Orange
Rear Right (-) - Blue/Black
150db in a commodore =
thanx for ya help i fitted my clarion dvd/cd 2day but not gettn sound out of head unit i rekn i got shafted and some knob has shorted out sound side then resold it as the main power wire has less than 10mm of wire to join 2 after black box and im sure it wouldnt of left the factory this way {bought from repco port lincoln sa} hopefuly they do somthing about it gggrrrrrhhhhhhhhh
Yep those short wires are a sign its not a "new" head-unit/
