Results 1 to 19 of 19
Thread: amp signal wire ???
    vy ss ute
    Feb 2010
    Default amp signal wire ???
    hey guys ive seen questions about getting the aerial to work with a new deck but i want to run a amp off my standard 6 stacker in my vy ute ive got all my gear sorted and the speaker wire into rca box but where do i run my amp signal wire to? on my old sytem the pioneer hu had just one aerial wire (blue) the stock head has a up and a down wire so what do i use to signal my amp?? any help would be appreciated
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    I would just connect it to the H/U power cable. That way the amp is only turned on when the H/U is turned on.
    Ronald Reagan (1986)
    vx s pack II
    Jan 2010
    aLKIDA
    vy ss ute
    Feb 2010
    yeah thats what i was thinking the ACC signal would do the trick. has anyone tried this on there amp before? im not too sure wether the signal is a contant (like when the ACC is on) or if its a puse? anyone able to clear that up for me?
    wraith's Avatar
    wraith is offline Hand over the dog bikkies
    '95 VR Series II
    Sep 2008
    Demonicaland
    Quote Originally Posted by lodgie View Post
    Should be constant.
    vx s pack II
    Jan 2010
    aLKIDA
    The ACC is a constant power supply.
    Make sure your head deck turns on when the ACC is on before you wire it up.
    Some cars use IGN for the head deck. I dont no why.
    But commodores use the ACC signal.
    If your not sure put the test light on the ACC wire to find out. test it with thye car running as well.
    But you will be fine using ACC signal.
    vy ss ute
    Feb 2010
    thanks guys, ill let you know how it works out as im doing the install today, cheers
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    Quote Originally Posted by PRAVX II S View Post
    What's the difference between IGN and ACC wire?
    vx s pack II
    Jan 2010
    aLKIDA
    Quote Originally Posted by StoneX View Post
    When you have IGN on the lights on the dash come on so does other things like EFI relay and fuel pump and if the radio is wired only to come on when IGN is on then
    This will suck Extra power. What if you wanted to listen to just the radio you would have to have the IGN on to do it. no point in wiring your remote signal wire to IGN.
    When the ACC is available. If you did wire it up to IGN then the amp will only turn on with the reds on.
    Why do you ask?
    vy ss ute
    Feb 2010
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    Why do you ask?
    Ahh... We always call IGN and ACC the same thing and what you're referring to as ON. But I'm not an auto elec
    vx s pack II
    Jan 2010
    aLKIDA
    Dont no what your trying to say but ACC/IGN are to different signals. They both will have 12volts available when swithced on to the corresponding mode.
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    Seen many head units with ACC/IGN wires and battery/back up wires. Which indicates they're the same thing.
    vx s pack II
    Jan 2010
    aLKIDA
    I don't no if were talking about the same thing i am talking about when the radio comes on in the car. ( When key is on ACC mode)
    I was saying some cars radio turns on when the IGN/RED are on instead of the ACC. The radio is a ACC.
  15. #15
    wraith's Avatar
    '95 VR Series II
    Sep 2008
    Demonicaland
    Yellow is constant 12V. Red is 12V only when car is on ACC and/or started.
  16. #16
    vx s pack II
    Jan 2010
    aLKIDA
    Quote Originally Posted by wraith View Post
    I know how a head deck works mate and the colours of the wires.
    If you read the earlier posts i was saying that it would be better to use the ACC wire to turn the amp on rather then using IGN/REDS
  17. #17
    vx s pack II
    Jan 2010
    aLKIDA
    I don't think we are on the same page here. I was saying that it is better to wire up the amp signal to ACC rather then IGN. So when the radio is on (When key is on ACC mode) the amp will turn on as well.
    Like i said before there is no point in wiring the amp signal to IGN but fill free to do what ever you want.
    Once more for the installers
    Have a think if the stock radio comes on when the key is in ACC mode and you wired the remote wire to IGN.
    Then every time the ACC is on (when the radio is on) the speakers wont work because the remote wire to the amp is wired to IGN.
    You would then have to turn the key once more to the IGN/REDS mode to make the amps work. So if you had this setup the only time the speakers would work is when the
    key is on IGN or when the car is running. THATS THAT.
  18. #18
    wraith's Avatar
    '95 VR Series II
    Sep 2008
    Demonicaland
    I was staying out of it but I fully agree with what your saying. Luckily most units out there do come with a remote trigger wire.
  19. #19
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    Yeah, I wasn't even talking about the original post. Just asking what definition of IGN wire and ACC wire were
  1. RPM signal wire
    By VScommodoreute in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-01-2011, 08:22 PM
  2. tacho question (signal wire???)
    By kezza_4246 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-09-2008, 11:00 PM
  3. head unit signal wire
    By maxpower QLD in forum Car Audio
    Last Post: 13-07-2008, 05:40 AM
  4. signal wire for air fuel gauge
    By guyver6 in forum Electrical Wiring / Questions
    Last Post: 09-10-2006, 08:49 AM
  5. MAP signal wire
    By defa in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-05-2006, 04:19 PM
