Sorry if this has been posted before but I want to upgrade the standard door speakers in my vz and am confused reading other posts relating to this. I understand they are all 6 inch speakers but the fronts are splits with the tweeters in the dash, so will I need to buy a pair of splits and a pair of 6 inches? Also how easy is it to replace the tweeters if I have to?
for the front you need 1 pair 6.5" splits. the door pod the woofer sits in will need to be cut back about 50% to fit.
and the tweeters are under the dash easy to get to and swap out with the new ones.
VZ-Rob
98 Ron Powerchip: CAI: SuperLows: GTS Swaybars: Tinted: SS Grille: SS Vents: SS 2:25 Twin Exhaust: ASR Audio:
you don't "have to" get splits for the front, if you are on a smaller budget there is no reason you can't go with coaxials
