Results 1 to 13 of 13
Thread: Fusion 6.5" or stock?
    VT Berlina S2
    Mar 2010
    Default Fusion 6.5" or stock?
    I just installed a fusion 6.5" speaker and a tweeter in my VT,
    i have only done one side so i can compare the two. The new 6.5" sounds a lot crapper than my stock paper cones. They are only running off the head deck would an anp make them sound better?
    thanks.
    Bumming lifts, saving up.....
    Mar 2009
    Cairns White Rock
    An amp would hardly make a difference.Just because your stock speakers aren't the best, dosen't mean cheap ones, like your Fusions, are going to be any better.What model are they from Fusion?
    What did you do about the factory tweeter when connecting your new speaker?
    It's really much of a comparison comparing a cheap factory speaker, to a cheap aftermarket speaker.
    VY executive ute s1
    Jan 2009
    speakers are made to run in pairs, and the headunit will need adjusting to match the new speakers. My odl speakers ran up to 25 before they started to crackle n pop, but my news ones can take up to 30 depending on the song, however they are alot crisper, and the bass is deeper.
    VT Berlina S2
    Mar 2010
    MR_VX's Avatar
    MR_VX is offline Forced to be Fast
    VX S pac SII Raptorcharged
    Mar 2009
    Townsville, Qld
    Quote Originally Posted by HCVP View Post
    i think ur wrong there, my 6.5 splits run way better off an amp, worth doing so.
    Check out my ride here >>>>My VX Raptor
    say NO to chev badges
    Wanted To Buy=>> Mace 12mm or 25mm Manifold spacers - VX SS Headlights - VY handbrake complete set up
    For Sale=>> vt/vx Berlina/Calais chrome window surround PM me for more details
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    Depends what you mean 'better', speakers will go louder with an amp, assuming speakers are rated to power of amp, but the quality will still be the same. Assuming here that you don't exceed the power output of the h/u.
    Ronald Reagan (1986)
    Mar 2009
    Cairns White Rock
    Quote Originally Posted by MR_VX View Post
    The reply was with regards to his choice of splits, not speakers in general.Sending them an amplfied signal from the same source, will not improve the quality itself.I guess i could have elaborated a bit more.
    With any audio upgrade, you want to ensure you are getting the most out if it.
    Without an upgraded source, amp, deadning, correct installation ect, then you can't expect any speaker to perform at it's best.It would be like getting a new cam, but without a tune to suit.This is why his aftermarket speakers, don't sound as good as he was most likely expecting them too.
    This is why i'm always trying to get the point accross to people that as far as value for your dollar is concerned, a speaker upgrade shouldn't nessacarily be the first on your list.There are gains to be made elsewhere whilst still retaining some of the factory components.
    I'm not saying there is no point in upgrading your stock speakers, only that for the money most people typically spend, it could have better spent elswhere.A $150-200 aftermarket head unit, with stock speakers, would outperform a stock head unit, running $150-200 speakers.
    VS 97 Series II
    Oct 2007
    Whalan, N.S.W
    Quote Originally Posted by benny105 View Post
    The speakers are reactor 6.5"
    thanks
    Hey Benny
    Don't underestimate those reactors. Amp and tune them and you will get good sound out of them!
    I won a SQ comp with a set of those! Not to mention also, that the judge from Option Audio was also blown away!
    My new ride with some upgrades.
    www.teamfusion.info
    Head unit: Fusion CA-CD500 Front Speakers: Fusion PP-CM650
    Rear Speakers: FusionPP-FR6520 Subwoofer: Fusion PP-SW120 Amp For Front And Rear: Fusion PP-AM120040 Subwoofer Amp: Fusion PP-AM300010
    VX Berlina S2 Gen 3 V8
    Feb 2010
    Echuca
    I Have a pair of 6.5 fusion splits with crossovers. They sounded awesome when I tested them at the store running an amp. I put them into a nissan trx running a MB quart amp. And my god they are good. Clean and crisp with a lot of bass and a decent amount of volume. I then installed them into my vx with the same aftermarket head unit, unamped, and had the same problem as you.
    The stock speakers have more bass and are louder unamped, but they aren't as crisp as the fusions. I am going to put the amp in and hopefully I get the volume and bass back.
    VZ Evec 05
    Jan 2010
    South Coast NSW
    just bought a set of Powerplant splits. Reactors were my first choice. Fusion mid-range gear is good but the powerplants were on special. you wont get the full potential out of any speaker unless you amp it and put some dynamat in....even the small speaker sheets will make a massive difference
    VE Commodore SSV
    Feb 2010
    Mar 2009
    Cairns White Rock
    VE Commodore SSV
    Feb 2010
    Yeah he did just buy the speakers but I wanted to know if he wanted to spend the money to buy an amp and sound deadening.
  1. fusion subs into my stock vx
    By vx aiden in forum Car Audio
    Last Post: 22-10-2009, 08:23 PM
  2. [SA] F/S: Fusion Powerplant 12" Sub & Amp.
    By jamesl_VTSS in forum Parts And Other Items For Sale
    Last Post: 06-04-2009, 09:50 PM
  3. FS: 2 Fusion SUBs in box, Fusion amp, Fusion Capacitor
    By BigDaz in forum Parts And Other Items For Sale
    Last Post: 08-03-2007, 04:48 PM
  4. fusion 6.5" 3 ways
    By lieos in forum Parts And Other Items For Sale
    Last Post: 10-10-2006, 07:16 PM
  5. fusion 4" splits in vn dash
    By ultimate_vn in forum Car Audio
    Last Post: 13-09-2006, 09:26 PM
Tags for this Thread
