Results 1 to 3 of 3
Thread: WH Stato Head unit upgrade
    2005 VZ S Ute
    Jan 2009
    Northen Adelaide
    Default WH Stato Head unit upgrade
    Hi All,
    Bought a gem 1 owner (deceased) WH 5.7 V8 stato for $8K a few months ago. The car is in showroom condition except for a few small door dints etc. The best bit is the car has only done 38000Km :-) .
    Anyway the Eurovox staker is giving me the beans , it plays a few track and skips and doesnt play some discs etc . I am thinking of replacing the head hunit , but will probably keep the existing factory speakers .
    Now Im guessing the factory setup has an amp somewhere and Im wondering what problems Im going to run into hooking up a head unit to the factory wirring .
    Im gessing the factory speakers would be different ohms than standard .
    Basically If any WH stato owners have been down this path I would like to hear from them .
    I know about the steering wheel controls . Im just worried about issues with impedance of the factory speakers / amp and if an aftermarket HU can handle a different load if the factory setup is different from 4 ohms.
    Matt
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    I think the statesman only has a separate amp for the subwoofer which is mounted on the parcel shelf. So the amp would require an audio input from the new head-unit if it has the stock subwoofer and you wanted to retain this, maybe someone with experience in the Statesman can clarify this etc. AFAIK the head-unit still powers the stock speakers. Also, they should still be 4 ohms. If in doubt, grab a multimeter and check the impedances on the speaker wires at the head-unit plug before installing the new head-unit.
    150db in a commodore =
    VYII Acclaim
    Jun 2008
    Largs Bay, Adelaide, S.A
    I recently upgraded a mates WH headunit.
    If you only have L/R front, L/R rear doors and 2 subs, it should be ok... The speakers are 4 ohms each.
    If you have anymore speakers, check the speaker impedance per channel at the H/U.
    The sub amplifier gets it's audio signal from the rear speakers.
  1. VY Head unit upgrade.
    By RicheCV8 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 13-01-2010, 07:29 PM
  2. New Head unit/audio upgrade help
    By vnsmanual in forum Car Audio
    Last Post: 07-01-2010, 10:37 PM
  3. VE Upgrade using existing head unit
    By Cav in forum Car Audio
    Last Post: 31-08-2009, 11:43 PM
  4. DVD head unit upgrade for my VT Series 1 Calais
    By VT97CALAIS in forum Car Audio
    Last Post: 25-11-2008, 09:20 PM
  5. controlling power antenna from stato head unit
    By kluckmeister in forum Car Audio
    Last Post: 08-01-2007, 11:45 AM
