Results 1 to 17 of 17
Thread: Amp has no power! HELP!!!!!
    VR CALAIS
    Mar 2010
    Unhappy Amp has no power! HELP!!!!!
    Hi,
    I have a Xplod amp with
    X2 Front factory tweeters
    X2 Parcel shelf 6x9's
    X1 Explod amp
    X1 JL audio 12" sub
    __________________________________________________ _______________________________
    Ok, my problem is that i have no power to my amp. The positive terminal recently broke and when touched on the place where the terminal goes i had power. It sparked a couple of times because it touched the negative. I checked fuses and put multimeter on the wire to the amp and i have power. it must be the amp. PLZ HELP !!!!!
    91 vn s
    Jun 2009
    Adelaide, SA
    Try with another amp to prove that the cables r fine. maybe REM cable got shot when the short happened...
    if not fuses then most likely ur amp has passed on
    but really the fuses should have blown b4 any damage could happen to the amp. hmm..
    wraith's Avatar
    wraith is offline Hand over the dog bikkies
    '95 VR Series II
    Sep 2008
    Demonicaland
    Verynice's Avatar
    Verynice is offline Band
    VS Caprice 5L
    Aug 2008
    SA - The Backwards State
    FULLY TURBO vw caddy van :(
    Jul 2008
    Castle hill
    Yep - i'd also be guessing it's the remote wire.
    Run a seperate wire from the headunit remote power outside the car to your amp.. If that fixes your problem you know there's either a short of a cut line somewhere.
    Check out my ride!
    Verynice's Avatar
    VS Caprice 5L
    Aug 2008
    get a small bit of wire and bridge/connect the positive and remote terminals on your amp together. If it powers up your remote wire is at fault. If not the amp is probably fried.
    VP Exec
    Mar 2009
    Melbourne, bayswater
    All you need is a circuit tester.
    I had the exact same problem as you mate, i was pulling my hair out for days. all it ended up being was the remote wire.
    And i figured that out by useing a circuit tester
    VR CALAIS
    Mar 2010
    Hey,
    Thanx guys
    i got a multimeter and looked for power coming out the positive negitive and the REM cables disconected from the amp and i found.....
    Positive: 13-14 amps or volts (whatever it is measured in i get confused)
    REM : 13-14 whatevers
    Negative i got no power at the terminal so i did it on the wire itself with the car runnning and CD on and i still got no reading. Its not fuses cuz there bridged.
    What do i do now?
    Ranga,
    JonnyDe's Avatar
    JonnyDe is offline Donating Member
    VE SV6
    Jan 2010
    Ayr, North Queensland
    You shouldnt get anything from the negative. Volt meters measure the potential difference between two points. 0 volts measuring at ground and the earth terminal is a good thing. seeing as you have more than 12 volts at both PWR and remote, then id say your amp is at fault, try another amp if possible
    VR CALAIS
    Mar 2010
    Yeah thats the thing i dont have an amp and im broke at the moment lol. Im gna save up and go to strathfield and buy a new sub,amp and get them to wire it up for me lol
    VE SS Sportwagon
    Feb 2010
    Brisbane - Southside
    SuperSixty6's Avatar
    SuperSixty6 is offline Alto Rullo
    Landcruiser TD
    Dec 2008
    Brisbane.
    In response to your readings, Say this is at your Amplifier:
    [ + ] - [Rem] - [ - ]
    With your Multimeter, When you held the probe on + and Rem terminals, Where did you get your neutral from?
    Then when you did it to your - terminal, Where did you get your positive from?
    Maybe i have missed something, I just didn't clearly understand your testing...
    VR CALAIS
    Mar 2010
    VR CALAIS
    Mar 2010
    Quote Originally Posted by SuperSixty6 View Post
    Wen i used the multimeter i put the negative probe on the boot lock bar as earth and put the positive on all of the wires.
  15. #15
    VS Executive
    Nov 2008
    Wollongong
    I reckon its the fuse in the amp.... open the amp up and test the fuse (or just look at it to make sure there is still a bridge/connection in it)
  16. #16
    VR CALAIS
    Mar 2010
    Landcruiser TD
    Dec 2008
    Brisbane.
    Quote Originally Posted by Ranga View Post
    Ok, So you should not have got any reading when you had one end of the probe to the boot latch, and the other probe on the negative? Correct? Did you then test your negative terminal on the amp to the postive on the amp? Did you then get a reading?
    I am just thinking along the lines of that your amp doesn't have a negative. Is it earthed correctly in the boot? And when the work on the battery was done, (I presume you run an external fuse in the engine bay) was that removed by chance hence no power?
    Cheers,
    Super6
  1. Options..power seats... power windows??
    By Hairy Eater in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-01-2010, 06:01 PM
  2. Power versus non-power steering columns?
    By BaggedVL in forum VL Holden Commodore (1986 - 1988)
    Last Post: 27-10-2009, 06:19 AM
  3. Constant Power to power window switch
    By stockies in forum Electrical Wiring / Questions
    Last Post: 02-05-2009, 08:14 PM
  4. VE 12 V Accessory Power Power Outlets
    By ansett727rma in forum Electrical Wiring / Questions
    Last Post: 24-08-2008, 07:43 PM
  5. Desperatly Seeking Power + Power + More Power
    By kezza_4246 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-10-2007, 10:28 PM
