Howdy all,
I have a bunch of questions i want to ask about the install i am planning.
Firstly, I currently have a decent pair of 4inch speakers in the factory position in the dash running off the head unit and i want to put some 6.5'' splits in the front doors and in the boot and these will be running off a 600w Pioneer 4 channel, so im wondering if the 4inch will distort badly and if it's even worth leaving them it?
Secondly, I want to make 2 custom boxes in the boot that will sit over the wheel arches between the back seat and the hatch to house 1 amp either side, a pair of 6.5'' splits as mentioned above and just behide the seat will sit a 12'' Reverse mounted subs either side.
My question is, is there a noticable difference between normal mounted subs and reverse mounted subs and which sounds better? I'm thinking of going reverse mounted because of the space issue with the wheel arches.
Thanks.
VN WAGGY! Bur Bur Bur Bur
Just to answer your first questioin, Personally I wouldn't bother with the 4"s and just run with 6.5's
Yep disconnect the 4"s in the stock locations. Those spots are a good place to mount the tweeters also.
As far as inverting subs goes, there isnt a huge difference in output IMO. Ideally you want to mount them normally, but in your case it'll be much easier to invert them.
150db in a commodore =
Alright thanks for the replies.
