Results 1 to 4 of 4
Thread: no power to amps
    vs executive II
    May 2009
    BRISVEGAS
    Default no power to amps
    hi all ive just hooked up my amps (kicker zx750.1 powering 2 12" kicker cvrs.. jl audio 300/4 powering 2 sets of polk audio mm651)
    my problem is when i first tuned the ignition i had no power to either amps so moved the wire around on the battery terminal and viola power to both amps and everything working well except my subs wernt going although there was power to the amp and was on,
    so i unplugged the battery terminal to try sort out the subs and when i connect the terminal again no power ive moved the power to 3 diff points on the terminal but none seem to be giving me power
    i have no idea what is going on the fuses are not blown and there was power b4 so why not now?
    any help pls
    ps i have a 300amp fuse near the battery and a 100amp fuse from distro block to jl audio amp im going to change the fuses to lower amp fuses on the wknd as i only need a 120amp near the battery and 40 amp b4 the jl audio amp but these are the fuses that came with my wiring kits so yer, and i dont have or have access to a volt meter either
    FULLY TURBO vw caddy van :(
    Jul 2008
    Castle hill
    Remote wire hooked up correctly?
    Amps earthed to a solid ground point? (and paint sratched off)
    Could be a short in either power or remote wires.
    And about no sound coming from the subs.. Are the RCA's defiantly plugged in.. if so they could be faulty, broken or could be a short in them too..
    I assume you have a fuse on the power wire near the battery, check the fuse is touching the terminals.
    Best thing i can suggest other than buying a volt meter and circuit tester, would be take everything out of the car and try and wire it up outside and test everything works.
    Check out my ride!
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    Use a multimeter or test light and measure the power before the main fuse holder and after the main fuse holder.
    vs executive II
    May 2009
    BRISVEGAS
    thnks for the comments but i shuda neva posted on here as it was something so stupid i cnt beleive i didnt figure it out..
    the new head unit goes in2 demo mode when i turn the ignition and in turn is technically on so its not sending a signal to the amps 2 turn on when it does this so once you actually put on the radio or chuck in a cd/hook up ipod etc viola amps turn on lol
    and yer the subs r goin now it was the rcas musta been when i jammed the head unit in
    thnks heaps anywais
  1. installed 2 amps but no power?
    By vscom88 in forum Electrical Wiring / Questions
    Last Post: 26-01-2010, 10:23 PM
  2. This Ones Got Me Stumped... No Power To Amps
    By sweefu in forum Car Audio
    Last Post: 16-01-2010, 03:26 PM
  3. JBL amps/RMS power ratings
    By jarusumo in forum Car Audio
    Last Post: 25-11-2009, 08:51 PM
  4. JBL amps/RMS power ratings
    Last Post: 29-10-2009, 07:45 PM
  5. Precision Power amps?
    By HCVP in forum Car Audio
    Last Post: 13-06-2009, 10:51 PM
