Results 1 to 11 of 11
Thread: Car Stereo Noise problem, Pls Help
    G4orce's Avatar
    G4orce is offline HSV Owner
    Vy Senator Signature 5.7lt auto
    Aug 2004
    Melbourne SE Subs
    Angry Car Stereo Noise problem, Pls Help
    Hey guys the other day i fitted new front splits into my Senator. These speakers are now hooked up to an amp in the boot of my car when the fronts used to run throught the head unit. The problem i am having now is that every time I turn of the ignitition there is a loud buzzing noise coming from all speakers for approx 5 Seconds. With my car when you turn the ignition off the stereo keeps running until you Open the drivers door. I had a little bit of a play with the rca conections to the amp and the buzzing is not as loud as it was now.
    I am not sure what could be causing this. Interferance problem with amp? problem from Head unit? wire arcing somewhere? If anyone has any ideas could you please let me know.
    My Beast VY Senator Signature 5.7lt Auto
    More info Click on like below
    vn_v6's Avatar
    vn_v6 is offline Blumpkin
    87 vl limited edition
    Aug 2009
    victoria
    it is your grounding to the rca's, take out your head unit, and solder a wire to the outer part of the rca plug, my vn had the EXACT same problem and as soon as i touched the wire there, viola, also to test if its this, partialy unplug the rca's, so only the prong is touching the amp, and the outer part isnt, if buzzing stop, 100% its your grounding
    Quote Originally Posted by Swordsy View Post
    If keyboads were cars, I'm sure half the people here would have been run down by now :P
    Quote Originally Posted by danja View Post
    GM: Has millions of dollars and highly trained engineers.
    Some guy in his backyard: Has a hole saw.Discuss.
    Quote Originally Posted by illusionalvr View Post
    just tow it around on a trailer and tell everyone its a turbo putting out 770 horses.
    vn_v6's Avatar
    Aug 2009
    victoria
    oh and then solder the other end of the wire to metal on the car lol dont just leave it hanging, forgot to add that
    G4orce's Avatar
    Aug 2004
    Melbourne SE Subs
    Quote Originally Posted by vn_v6 View Post
    hahah I gathered that is what you meant. I will give that a shot for sure and see how it goes.
    Thanks mate
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    Do you have a Pioneer head-unit, as the RCA grounding issue is only with the Pioneers AFAIK.
    It could also be that the amp is either turning off or staying on while the head-unit is doing the opposite. Where did you get your power for the remote on the amp?
    150db in a commodore =
    G4orce's Avatar
    Aug 2004
    Melbourne SE Subs
    Quote Originally Posted by holdenboy View Post
    Nah its a JVC head unit. I got the power for the remote wire from the back of the head unit. I have checked, the amps switch off when the should (when door opens after switching car off)
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    Hmm, well ok it's not a remote power problem and I doubt it'll be the RCA grounding as it's a JVC unit and I've never heard of a JVC doing it, only Pioneer. Where did you ground the amp, and did you sand back the area so it makes good contact?
    G4orce's Avatar
    Aug 2004
    Melbourne SE Subs
    Hey mate i did sand back the area before grounding the amps, I have grounded them to the boot on a good point, I used to do car stereo installs and have used this spot many times, but this problems has me stuck. Checked the RCAs by grounding them and that is not the case on this occassion. Might just spend my days off pulling the car apart and checking all the wiring but I know that it was all installed correctly. Just worried it could be the amp now...
    G4orce's Avatar
    Aug 2004
    Melbourne SE Subs
    just went through the all the wiring and found a few exposed wires so i just taped them up. Still got the annoying buzzing noise. Not sure where to go now
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    Try another amp?
    Try another head-unit?
    Try powering the amp from a second battery not connected to the car?
    That should keep you busy for a while. Other than the above i would also try another set of RCAs or even an iPod / MP3 player plugged straight into the amp via an adapter cable.
    slipstream001 is offline -=Slipstream=-
    VR Senator II
    Jan 2007
    Werribee, Victoria
    try to use another input feed, like an ipod with AUX - RCA outputs directly into the amp set the test to the same as when you usually turn the car off and open the door with only the ipods audio playing if the noise is still there then its not the head unit or your RCA's it will be either your remote wire / power wire / amp / speaker cable / earth, next eliminate your speaker cabling by undoing them all and using another speaker if it still does it then its not your speakers or speaker cable, next you could bridge the power cable and remote input and use an inline switch to manually control your amps on/off function...continue through eliminating things until the problem is found, i'm not exactly sure how the wiring works for the open door audio off part but its possible that could be causing the noise which may have always been there but the amp is amplifying it..?
  1. Stereo Problem.
    By Deneo in forum Electrical Wiring / Questions
    Last Post: 18-03-2010, 04:51 PM
  2. Stereo loud noise when starting car
    By OBR1EN in forum Car Audio
    Last Post: 22-05-2009, 08:23 PM
  3. The Kings guide to elimanating stereo noise.
    By Tasmaniak in forum Car Audio
    Last Post: 05-03-2009, 10:53 PM
  4. VY stereo noise problem
    By VY2ENJOY in forum Car Audio
    Last Post: 23-01-2006, 01:58 PM
  5. whine noise coming thru stereo
    By pizzo in forum Car Audio
    Last Post: 12-07-2005, 12:20 AM
