Results 1 to 7 of 7
Thread: can someone recommend an Amp pls
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    Default can someone recommend an Amp pls
    lo' all.
    could someone recommend an mono block amp to run my 10 inch subs. looking for entry level stuff but not as crap as ebay. would really like something that has 30hz low pass.
    the drivers are a japanese brand that came out of one of my imports (owner didnt want them) no power ratings on them but the magnets are huge and you can tell they are quality. would guess up around 150W RMS each.
    there are two in the box, dimensions at a guess would be around 30 litres total area with two 80cm vents which extend 20cm's inside. i know its a small box but i was limited on space in my boot.
    its been such a long time since i looked for amps i dont even know where to start. i had a quick look at jaycar, but their response stuff doesnt seem to be all that cheap anymore. was hoping for something around the $200 mark, no more than 300.
    thanks in advance
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    You need to know the impedance of the subs and how they're wired (series/parallel) before you even take any recommendations.
    Why do you want a 30Hz low pass filter? I think you may be confused. With ported boxes people sometimes HIGH pass at around 30Hz to prevent the sub from "unloading" below the ported box's tuning frequency. The LOW pass filter is usually set somewhere between 50-100Hz. 80Hz is a good starting point, then adjust from there to see what suits your subs and speakers.
    ari666's Avatar
    1966 impala
    Mar 2009
    hi mate.
    i will just assume they are 4ohm and they are wired in parell (...think back to high school, um) the two drivers are running off one input on the side. so i guess that makes them ... 8ohm? but it goes the other way doesnt it, so 2ohm. lol.
    the reason for the low pass is that i want to kill off any and all high freq noise. there are 6x9's and 6.5 splits to handle that. i just want punch.
    anyways, on the given (albeit crap) information, any suggestions?
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    Yeah, if they're 4 ohm each and wired in parallel, it will be a 2 ohm load to the amp. All monoblocks will run 2 ohm, since you don't know the power rating of the speakers, I'd just look at a mono that does 300-500Wrms @ 2 ohm.
    30Hz is way too low. Everything under 30Hz is nearly inaudible. You'll want an 80Hz low pass filter or adjustable one. Then you high pass the speakers above 80Hz.
    Just an example of how easy it is to find something
    Ryda Car Audio - Pioneer Car Audio GM-D7400M Car Amplifier($263.85)
    Ryda Car Audio - Kenwood Car Audio KAC-8104D Car Amplifier($208.85)
    Ryda Car Audio - Clarion Car Audio APX1301 Car Amplifier($172.20)
    Ryda Car Audio - Kicker ZX300.1 Mono Bock Amplifier($242.95)
    http://www.ryda.com.au/Soundstream-L...r-p/lw1350.htm
    ari666's Avatar
    1966 impala
    Mar 2009
    yeah, i been through the whoe range of ryda's stuff. still doesnt tell me whats good 'bang-for-buck' value though.
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    Clarion is good quality for quite cheap, Soundstream are more expensive but apparently very good quality. I've used Pioneer amps before, good price, and never let me down.
    Is that what you wanted to know.
    Ronald Reagan (1986)
    ari666's Avatar
    1966 impala
    Mar 2009
    yeah well the clarion is the cheapest of the bunch up there. so yeah, thanks
  1. Recommend me a wax...
    By Michael_123 in forum General
    Last Post: 29-11-2009, 08:39 PM
  2. Recommend some games
    By AirStrike in forum The LAN Lounge
    Last Post: 16-07-2008, 06:10 PM
  3. what oil would you recommend?
    By sebstenator in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-06-2008, 03:22 PM
  4. What would you recommend?
    By VSSPak in forum Car Audio
    Last Post: 19-12-2006, 10:30 PM
  5. Recommend a setup for VT
    By AirStrike in forum Car Audio
    Last Post: 03-11-2005, 07:02 AM
