Results 1 to 9 of 9
Thread: VS Commadore Stereo System Instalation HELP!
    VN Berlina
    Oct 2009
    Angry VS Commadore Stereo System Instalation HELP!
    Hello I recently bought a Stereo system (Pioneer 6x9, Alpine CDM-7859, Boss BA-2200 2 channel 400w Amplifier). That I am trying to put into a 1996 VS Commadore
    I am having trouble with the wiring guides I have found online.
    The colour wires I have in the car are:
    Black-White
    Yellow
    Yellow-Green
    Orange-Purple
    Blue
    Grey
    Brown-Black
    Light Green
    Darrk Green
    Black-White
    Black-Orange
    Tan
    And the radio has the following wires:
    Ignition: RED
    Ground: BLACK
    Power Antenna:BLUE
    Battery: YELLOW
    RL+: Green
    RL-: Green/Black
    FL+: White
    FL-: White/Black
    FR+: Grey/Black
    FR- Grey
    RR+: Purple/Black
    RR-: Purple
    So if any1 could help me with this it would be great.
    Also I put the suboofer and amp into the car and wired it up. and its not getting power any reason why??
    Thanks Heaps
    Bumming lifts, saving up.....
    Mar 2009
    Cairns White Rock
    You've left a fair bit of info out of your post.Anyways, asnwer the following and we can go from there.
    Does the head unit power on?
    If not, refer to this thread in order to match up your wiring. VK-VZ Stereo wiring colours. Ensure you have done everything correctly.
    I'm assuming the 2 channel amp is to run the sub? And you are running the speakers off the head unit?If not, then let us know otherwise.
    How have you connected the amp?
    Do you have-
    Power cable (with an inline fuse)
    Earth Cable (of suitable guage and connected to a bare metal surface which touches the car's chassis?)
    Trigger cable, (connected from your amp to your head unit?)
    Are your RCA's connected to the correct pre-out on your head unit?
    Finally, make sure you have disconnected the battery before begining. Check that you haven't blown any fuses as a result of not doing so.
    Does your head unit have a sub on/off function (some units do, and are default switched off when you first install them)
    VN Berlina
    Oct 2009
    Yes it does power onbut then itsays protect. I am unsure to why this is and cannot find it in the user manual. The Amp is powering only the sub atm. but there is no power running into the amplifier I havn't conected this to the head unit via the cable or with the rca cables. But i thought it should still be recieving power
    Mar 2009
    Cairns White Rock
    Connect the trigger wire from the amp to the head unit.The protect light is like a stand by light also, all you've done so far is connected the power and earth.
    Finish the install before assuming ti dosen't work.
    BoNeZ-01's Avatar
    BoNeZ-01 is offline "..of mice and men.."
    '95 Cino(daily driver), Project: VS.
    Mar 2010
    Central West, NSW(middle of nowhere).
    Yellow = Accessories.
    Orange/Violet = Battery feed.
    Black/White = Ground.
    Grey and Light Brown = Left Front Sp.
    Dark Green and Light Green = Right Front Sp.
    Yellow/blue and Brown/Black = Left Rear Sp.
    Blue/Orange and Blue/Black = Right Rear Sp.
    Yellow/Red = BCM(Body Control Module) For Power Aerial.
    Grey = Radio Remote Module.
    This is according to Gregory's VS Workshop Manual.
    It's not shown in the book, but I 'think' Brown/White = Illumination?
    On the 7th day, God created Holden, then on the 8th day, God created Ford, to keep idiots out of Holden's.
    Quote Originally Posted by destiny View Post
    so im gonna need a supercharger? fck that ruined my dreams, oh well, it will b easyier to get a turbo then i dont have to pay for the boost..
    wtf? im not stupid, theres no such thing as a tyre valve
    BoNeZ-01's Avatar
    Mar 2010
    NOTE: The wires you see in the VS, may 'not' be the same colour as those I posted, if someone has hacked at the original harness, and added different coloured wire extensions.
    In this case, you would need to trace back to the original harness, to make sure you have the correct wire colours.
    There are also other wires in the area behind where the radio sits, which are not part of the sound system.
    VN Berlina
    Oct 2009
    Mar 2009
    Cairns White Rock
    BoNeZ-01's Avatar
    Mar 2010
    Sweet as, hope I helped somehow.
  1. stereo system
    By holiday2 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 05-01-2006, 12:03 AM
  2. Stereo Stolen, getting a new system
    By Stewart1000 in forum Car Audio
    Last Post: 17-11-2005, 08:13 PM
  3. DVD/stereo system
    By FINCH in forum Car Audio
    Last Post: 12-10-2005, 04:07 PM
  4. adding amp to stereo system...HOW??
    By vy_pete05 in forum Car Audio
    Last Post: 12-10-2005, 12:40 PM
  5. New stereo system questions...
    By vl_boy03 in forum Car Audio
    Last Post: 03-06-2004, 12:33 AM
