hi ive just put an aftermarket headunit in my vy, which had the original loom from the blaupunkt unit plug into the back.
however, it seems im not getting any constant power as the radio stations reset each time and so does the eq settings.
any ideas on why this would be?
mark
How did you wire in the aftermarket head-unit?
The constant power wire (yellow) isnt receiving a constant 12v. Check that the yellow wire has power all the time, even when the key is off and the door is opened etc.
150db in a commodore =
id hazard a guess your memory and accesory wires are the wrong way around. pull it back out and switch the red and yellow wires over.
i have the same problem, i used the aerpro harness adapter. did you use the same or hard wired? its driving me insane
in life some people need a little guidance, others just need a good kick
maybe pull the deck out and use a test light to find the constant power and acc power and switch the wiring in the harness adapter to suit...just a suggestion ?
