Hi everyone, I am new to here. I have been reading all the articles regarding to sound system options for VE Commodores. I just bought amp and speakers from JB Hifi in Epping (Melbourne). The parts I bought are; (I hope I made a good mix and match)
- SONY XMGTX6040 4/3 Ch
General
Channel Configuration 4/3
Power Supply MOSFET Power Supply
Maximum Output Power 150W × 2 (at 2 ohms) + 300W × 1 (at 4 ohms BTL), 110W × 4 (at 4 ohms)
Rated Output Power 70W × 4 / 1.0% (at 2 ohms), 60W × 4 / 1.0% (at 4 ohms)
High Pass Filter / Slope 80Hz (Variable), -12dB/oct (Selectable)
Low Pass Filter / Slope 80Hz (Variable), 18dB/oct (Selectable)
Frequency Response 5-50kHz
Signal-to-Noise Ratio 100dB
Total Harmonic Distortion (1kHz) 0.05%
Input: Number of Channels 4
Tolerance +0/-3dB
Dimensions (W x H x D) 384 × 55 × 252mm
Weight (kg) Approx. 3.1kg
- KICKER 08-KS6502 6.5" CAR STEREO COMPONENT SET
6-3/4" KS Series Component System
Power Handling:
Peak: 300 watts per set / 150 watts each side
RMS: 150 watts per set / 75 watts each side
Injection molded polypropylene cone woofer
Santoprene surround
1" Aluminum dome tweeter
Neodymium magnet with ferrofluid
Includes symmetrical 12 dB/octave high pass and 12 dB/octave low pass crossover/protection network
3-Position tweeter attenuation
Includes metallic finish and grilles
4 ohms impedance
Top-mount depth: 2-1/8"
- New KICKER DS 650 DS-SERIES 6.5 COAXIAL SPEAKERS
Specifications
6-1/2" 2-way Speakers
Power Handling:
Peak: 200 watts per pair / 100 watts each
RMS: 100 watts per pair / 50 watts each
Impedance: 4 ohms
Woofer Composition: Polypropylene
Woofer Surround: Ribbed Poly-Foam
1/2" PEI (Polyetherimide) dome tweeter
Neodymium tweeter magnet
New Enhanced BAM (Basket and Motor) Assembly
High-Power Tinsel Lead Wires
Sensitivity: 90 dB
Frequency Response: 40 Hz - 20 kHz
Top mount depth: 46 mm
Cutout Dimensions: 138 mm
The Sony Amp I got has a high input connection. What I concern is whether the amp will suck any engine noise or not if I use the high input connection? And Which method of installation will be better to use LOC and RCA connection or High input connection?
According to what I have found in the articles on the site, there are three top brands to use to as a LOC such as CACHE COE6, AudioControl LC6, and RE-Q. I found some deals of these products on the online and also at JB Hifi. I will be happy if anyone gets me better prices on these products...The prices I got are;
JB HIFE PRICES:
LC6 $260AU
RE-Q $160AU
Online Prices
LC6 $175USD including the delivery from US
AudioControl LC6i (lc6-gray) - Factory Sound Processors - Sonic Electronix
RE-Q $120USD including thedelivery from US
MTX RE-Q CAR AUDIO BASS & SIGNAL RESTORATION PROCESSOR - eBay Processors Only, Signal Processors, Car Electronics, Electronics. (end time 18-Apr-10 14:44:58 AEST)
CACHE COE8 $180USD
NEW CACHE COE8 REMOTE LEVEL CONTROL 8-CH. LOC - eBay, Other, Car Electronics, Electronics. (end time 24-Apr-10 07:24:04 AEST)
Also what I think is whether there can be any fake production of these converter units?
Plus is there anyone who can help me out in fitting of the speakers and the amp at some reasonable price in Melbourne?
I will be so happy if you guys help me out in this...Thanks
