Results 1 to 7 of 7
Thread: Sub seized up
    Vr acclaim
    Dec 2009
    Default Sub seized up
    Well my sub just seized up and i was wodnering if that means get a new one or is it fixable?
    It is a cheapo sub so im not gunna go to great efforts to fix it if it is possible.
    And i was wondering if it isnt possible to fix. Is it possible for me to run a set of 6x9 off my pioneer mono block. GM-D7400M but i want them to play music not just bass like a sub would.
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    Firstly, it is possible to fix a blown subwoofer but as its only a cheap then the manufacturer probably dosent make the required parts, also it wont be worth the cost (cheaper to buy a new sub).
    Secondly, you wont be able to power any speakers off the monoblock (including 6x9s) in full range / music applications. They're not designed for that as the response bandwidth is 10-240hz.
    150db in a commodore =
    Vr acclaim
    Dec 2009
    Ok thanks, Cleared it all up there
    New sub here i come!
    Can u suggest a worthy sub to buy for the mono block i have?
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    Depending on what size the old sub was (use your current box) and how much you want to spend.......
    I'll assume its a 12
    If you want to stay with Pioneer, the TS-W308D4 is a good choice for under $200.
    Otherwise, heres a few other suggestions under the $200 mark:
    Kenwood
    Soundstream
    Vr acclaim
    Dec 2009
    Yea its a 12inch ported. Im guessing most 12" are the same size and if i pull my old one out nearly all other 12" should fit in?
    Im assuming all these subs u said here will perform around the same mark? I do have all pioneer but i dont mind mixing it up for most quality
    And would it be better to get a Sub at 2ohms or 4ohms?
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    The majority of 12" subs use a similar mounting diameter, so yes most 12" subs will fit.
    Yep they'll all be around the same sort of output, within 1-2db anyway (not really noticeable).
    Definitely go with a 4 ohm dual voice coil sub (2 ohm final impedance with the coils wired in parallel). This doubles the output of your amp, from 200wrms to 400wrms.
    Vr acclaim
    Dec 2009
    Ok awsome thanks for all your help.... Now to pick which one haha
  1. vr ss handbrake seized
    By Rusty in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-07-2010, 07:48 PM
  2. Ecotec seized. why?
    By blackbedford in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-01-2009, 09:56 PM
  3. seized oil pump... wtf
    By bradlei in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-09-2008, 01:44 PM
  4. engine seized?
    By vycalais in forum VY Holden Commodore (2002 - 2004)
    Last Post: 13-02-2008, 11:13 PM
  5. Handbrake seized
    By G Min in forum VL Holden Commodore (1986 - 1988)
    Last Post: 18-01-2007, 05:33 PM
