Hey Guys, when i got my head unit fitted my Radio Antenna worked fine for ages and now its just stopped working, but the thing is every month or two it will randomly start working again for a week or two, could it be loose wiring?
Maybe its loose wiring, maybe the antenna is on the way out.....could be either.
If nothing else changed (didnt take the head-unit out for any reason etc). Then i'd say a faulty antenna.
150db in a commodore =
It might be worth checking the antenna line and seeing if you are getting 12 volts on it when the antenna is supposed to be going up or down. I had an intermittent fault with mine awhile back and it turned out that the screw securing the earthing line was loose.
