i know the antenna wire is the blue and white ones but from the HU i'm running (Pioneer DEH-6150BT) the blue wire is for the amp etc and im pretty sure there is no wire for the antenna from the HU loom
The blue / white wire is used for the power antenna AND for the remote turn on of external amps.
So yep, connect the blue/white wire to the yellow/red wire in the cars loom. If you're running external amps then just splice into this wire also.
150db in a commodore =
theres no blue/white from the headunit but there is one from the car loom, connect that to the amp wire too you reckon?
do as , as in the pic
EDIT: StoneX beat me again.
ah yep, sorry i wrote that post out without looking at it, just what from what i remembered :P
anyway all sorted now i wired them togetherthanks
