Results 1 to 13 of 13
Thread: New head unit has no memory?
    v6vpute's Avatar
    v6vpute is offline Rolling on stockies
    1993 vp s sedan series 2
    Jun 2009
    Lakes entrance vic
    Default New head unit has no memory?
    hey guys just got my new head unit in to day and it has got know memory does this mean i havent connected it to a constant source of power and just accessories?
    thanks
    2005 VZ SV6
    Jun 2009
    Australian Crapital Territory
    BoNeZ-01's Avatar
    BoNeZ-01 is offline "..of mice and men.."
    '95 Cino(daily driver), Project: VS.
    Mar 2010
    Central West, NSW(middle of nowhere).
    What brand/model is the head unit? Did it come with an owners manual?
    Most after market stereo's have a red wire, that needs to be hooked up to your ignition wire, this turns it on.
    And a yellow wire, which needs a constant power, for memory.
    On the 7th day, God created Holden, then on the 8th day, God created Ford, to keep idiots out of Holden's.
    Quote Originally Posted by destiny View Post
    so im gonna need a supercharger? fck that ruined my dreams, oh well, it will b easyier to get a turbo then i dont have to pay for the boost..
    wtf? im not stupid, theres no such thing as a tyre valve
    v6vpute's Avatar
    Jun 2009
    Lakes entrance vic
    ok thanks and its a clarion lol and yeah i thought i wired the yellow up right but i dnt lol so i could run a wire from the yellow(power) to the battery?
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    Yep you could wire it directly to the battery (with a fuse within 30cm of the positive terminal). Or you can just use the Orange/White wire in the stock loom.
    150db in a commodore =
    hakhawk's Avatar
    hakhawk is online now smooth moderator
    BMW E21 320i, E36 318IS coupe
    Jan 2005
    this for the vp?
    yellow from headunit goes to orange on the car
    red from headunit goes to yellow on the car
    BoNeZ-01's Avatar
    Mar 2010
    Quote Originally Posted by v6vpute View Post
    Well it depends, I'm not sure exactly what the colour codes are for VP.
    You may need to buy a Gregory's manual first, to find out the correct colour codes.
    On my VR & VS, I think it's: Yellow = Accessories, and Orange/Violet = Battery.
    v6vpute's Avatar
    Jun 2009
    Lakes entrance vic
    lol there is no wiring sept for the accessories and earth sum one ripped it all out so im starting from scratched does the cigarette lighter have constant power?
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    no ciggy lighter is switched power
    v6vpute's Avatar
    Jun 2009
    Lakes entrance vic
    hakhawk's Avatar
    Jan 2005
    BoNeZ-01's Avatar
    Mar 2010
    Oh crap, that sux.. lol
    Nah the ciggy lighter is accessories too, but if you trace back far enough in the harness, you 'may' be able to locate the original wiring(if you're lucky).
    Failing that, either check you fuse panel, and locate the fuse for the stereo's constant power(should be separate from accessories).
    Or the harder way, run a new wire through the fire wall to battery, through one of the rubber grommets.
    As was said before, put an in-line fuse in close to the battery.
    v6vpute's Avatar
    Jun 2009
    Lakes entrance vic
    ill have to run it to the battery if i cant find the original ill hopefully connect it to that
  1. head unit has no memory..
    By Jamie-b in forum Car Audio
    Last Post: 27-09-2009, 11:51 AM
  2. Replacing VT head unit with BT ipod unit
    By nickbedford in forum Car Audio
    Last Post: 23-06-2009, 03:00 PM
  3. Head-Unit Help!!
    By Stoppa in forum Car Audio
    Last Post: 13-05-2009, 06:31 PM
  4. VE Head unit in a VZ??
    By scottishgit in forum Car Audio
    Last Post: 19-10-2006, 01:19 PM
  5. head unit
    By stevenwilson in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 17-10-2006, 06:02 PM
