Results 1 to 12 of 12
Thread: need a box for 2 12" response subs 300wrms each
    VT calais 1999
    Jun 2009
    Gympie
    Default need a box for 2 12" response subs 300wrms each
    hey all i am looking for a sealed boxed for my subs to go in my vt calais now the Vas for one of these sub is 72.5Liters if someone can design boxes i would like some to draw up the plans for me and i buy them
    VY Berlina V6 / R31 Skyline
    Dec 2008
    145 litre for 2 12" subs sealed? I think that might be for ported mate that = about 5 cu.ft or something huge.. maybe something like 1.3cu.ft each is better for sealed?
    Quote Originally Posted by xVisions View Post
    driving without a license at the moment, My vl has beaten every single car I've street raced!!
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    VT calais 1999
    Jun 2009
    Gympie
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    Too easy, its a little on the small side but those subs dont mind a small enclosure (1 cu.ft. each minimum).
    150db in a commodore =
    VT calais 1999
    Jun 2009
    Gympie
    ok thanks heaps mate just had a look at your wagon sub set up looking very nice just wondering if u can tell me what your running for ur hole setup speakers amps that sorta thing
    sorry got a lil side tract what should i use as sealent on the inside and also is it worth putting that white stuff(filling) in the sub box and should i divid the box so theres a wall in the middle of them or just leave it as on chamber??
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    Haha, my wagon used to have 2 x 15" subwoofers and a 4000wrms monoblock. Ive got Digital Designs DDC 6.5s in the front with a 2 x 150wrms running them, although now ive sold the subs and mono. Was good for 151db in SPL comps.
    Anyway, use PVA glue for glueing the MDF together, once youre done doing the joins run a bead along the inside to seal it off. If the subs sound a little "hollow" you can add acoustic filling to give the subs a deeper sound. Dont divide the box up, IMO it just takes up space and makes no difference, especially when youre running them off a monoblock or bridged outputs of an amp. (Both subs see the same signal, as opposed to speakers which receive a L and R signal).
    If you (and any others ofcourse reading this) want some good tutorials on building subwoofer boxes, including port calculators head over here:
    (feel free to sign up to the forums too ofcourse )
    Articles | DecibelCar.com the SPL Knowledgebase
    VT calais 1999
    Jun 2009
    Gympie
    VT calais 1999
    Jun 2009
    Gympie
    hey mate do u have a designe for a triple chamber box designe for the same subs
    VT calais 1999
    Jun 2009
    Gympie
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    Nope, thats going to be much harder to build and get tuned right, if your not confident then its best to stick with sealed. I'll make you up an enclosure for 3 12s tonight as i dont have time right now.
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    Alrighty, if you want a sealed box for 3 of those 12s, just extend the width from 80cm to 110cm (hopefully that fits in between the strut braces?) and extend the depth from 30cm to 35cm.
    That will give you a box volume of 3.3 cu.ft. after sub displacement (1.1 cu.ft. each sub).
    So as far as the cutouts go, obviously the front and back panels change from 800mm x 350mm to 1100mm x 350mm and the top / bottom changes from 800mm x 300mm to 1100mm x 350mm.
    The side panels also change from 318mm x 268mm to 318mm x 318mm.
    3 x 12s, what amp is going to power them?
  1. [VIC] 2x12" Jaycar Response DVC Subs in Box ~cheap~
    By georgeonboost in forum Parts And Other Items For Sale
    Last Post: 04-01-2009, 11:03 AM
  2. FOR SALE: Precision Response AMP/SUBS/CAPACITOR (SE Subbs, VIC)
    By Wagon_Wheel in forum Parts And Other Items For Sale
    Last Post: 29-06-2008, 10:27 PM
  3. Pioneer 12" Sub - In Box - 600watt max - 300wrms
    By 1991_Vn2nV in forum Parts And Other Items For Sale
    Last Post: 05-03-2008, 11:38 PM
  4. FS [SYD]: 2 x response 12" subs (dual 4ohm voice coil)
    By synical in forum Parts And Other Items For Sale
    Last Post: 20-12-2007, 01:06 PM
