Results 1 to 19 of 19
Thread: Ute Sub Box for 12" Alpine Type-R
    VY SS UTE
    Jun 2009
    Mandurah, WA
    Default Ute Sub Box for 12" Alpine Type-R
    Hey guys ive got a VY SS ute and im trying to fit a 12" alpine type-r sub.
    Atm its in a alpine ported box fixed down in the tray, with the lockable hard cover it rattles like crap and the majourity of the sound doesn't reach the cabin.
    I've concidered extending the port into the cabin but i am worried about cutting out a slot in the wall behind the drivers seat.
    I've designed a ported box and sealed box that could fit in next to the fuel tank but not quite sure if either would fit.(would be a really really tight fit)
    Also tried to design a box that would fit behind either the drivers or passengers seat but the sub needs such a large volume to run at optimum efficency that it wouldnt be practible.
    Has anyone fitted a 12" alpine type-r sub into a ute and it works really well?
    also any other ideas as a way to fit it?
    cheers in advanced
    VZ sv6 ute
    Mar 2010
    i have a apline type-s in a ute box behind the drivers seat in my VZ. have you looked at getting a ute box? as they run up the wall a bit as well
    VY SS UTE
    Jun 2009
    Mandurah, WA
    yeh ive looked at getting a box that goes behind the seat but im pretty sure there too shallow as the tyre r needs at least 195mm mounting depth and i think they're too small aswell
    VY SS UTE
    Jun 2009
    Mandurah, WA
    Does anyone have the measurements for the "behind the seat" ute sub box?
    I need the measurements to make sure it will fit and perform at its best before I go and buy one.
    thanx
    VY SS UTE
    Jun 2009
    Mandurah, WA
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    Quote Originally Posted by W45H1NGT0N View Post
    That won't work unless it's a bandpass box. With a ported box the sound from the cone and the port interact to give the tuning of a ported box, if you separate the port and cone you end up with messed up sound.
    But see the picture below of a bandpass box, the cone and port are in the same area and all the sound vents from the port... Bandpass boxes are difficult to design to sound good though.
    VY SS UTE
    Jun 2009
    Mandurah, WA
    ok yeh i thought it might muck up the sound. yeh bandpass box would b good but designing it would b a pain
    1999 vs ute series 3
    Oct 2009
    i tried to fit a type r in the fuel cell in my vs ute and failed misserably, its just to big. im lookn at the type s shallow mount for either behind the seat or in the tank cell atm
    Quote Originally Posted by Jonnii View Post
    yeah well it is a ute its not supposed to be about comfort
    http://forums.justcommodores.com.au/...rst-car-d.html <<< My 5sp vs ute
    VY SS UTE
    Jun 2009
    Mandurah, WA
    VS III 5spd Ute
    Apr 2010
    Lake Macquarie
    IMO there's not enough room to run a 12" that sounds good in a ute. period. 10" ported from the fuel tank is best bet. If putting a 12" in you will never get a box big enough that physically fits in for it to sound right (unless it's sitting on your passenger floor.)
    VY SS UTE
    Jun 2009
    Mandurah, WA
    smokyJ - haha yeh after researching this issue for about the last 3 months i have come to that conclusion as well.
    What would be a good sub and amp to go with, what location and what box?
    Cheers for the comments guys
    VS SS Series III Ute + VZ SS Thunder
    Jan 2009
    12 inch type R sub will fit next to the fuel tank in a VS ute Ive done it so I don't know what your doing wrong and they fit even better in vu up to ve
    you just have to make the box look kinda an L and the sub faces up, make sure you do the math for volume and displacement of air and expansion chambers etc if its a type r or you will just be wasting your time, I still have my sub box out of my vs with the type R sitting in it in the shed till I build a new box for my vz as the size next to the tank is bigger and the vents to the cab are different
    Jan 2009
    And a 12 will sounds crisp in a ute if you put the time and effort in to do it the right way, and port it to the cab my 12 was in a sealed box its hard to explain but I had awesome clear base and that was at 4ohm
    VY SS UTE
    Jun 2009
    Mandurah, WA
    i had wanted a ported box, thats y it was such a shit to get in there, the exact size box down to the very last litre for tuned at i think 32hz was like an 8L port and 35L box excluding the size for the wood and the sub itself. and the space is so small that the sub has to be facing towards the front of the car. so please dont tell me it was easy
  15. #15
    sp001in's Avatar
    sp001in is offline vyma100
    MALOO R6
    Jul 2005
    QLD
    This is my setup. 2 x kicker 12" comps.
    custom fiberglass boxes. 1 behind passenger seat (shown) 1 behind drivers seat. they are sealed 23litres. with wadding inside.
    Check out my build <---Click me
    Now sporting ASR audio interior lighting and stereo mods, and MACE induction mods.
    Need your computer tuned, or dash calibrated??? Want your PS3 fixed, or wish to prevent the YLOD?
  16. #16
    VY SS UTE
    Jun 2009
    Mandurah, WA
    nice man, looks good.
    i wanted to do something different, as far as i know no one else has put an alpine type r 12inch sub in the long range compartment
  17. #17
    2007 VZ Ute
    Aug 2011
    Im looking at putting a 10inch sub in my VZ ute but cant decide whether to put it behind the passenger or drivers seat? Im reluctant at putting behind the drivers seat as i dont want to get punched in the kidneys while i drive. However the jack and crap are behind the passenger seat leaving with little space. I know i could move the jack but i dont want to. I have seen enclosures that sit over the jack but this then reduces the size of the box. Has anyone had any experience with a 10inch from behind (hahaha) I threw that in for a laugh. No seriously do you get vibrated out of your seat if you install a 10inch behind the drivers seat? Thanks
  18. #18
    VY SS UTE
    Jun 2009
    Mandurah, WA
    Quote Originally Posted by The B Man View Post
    The B Man: Hey i have an alpine type r 12inch sub in the long range compartment which is directly behind the passengers seat. even though it has a crazy amount of bass for a ute its still very livable. i honestly dont think u'd have to worry about too much bass with a 10inch sub.
    cheers
  19. #19
    2007 VZ Ute
    Aug 2011
    Thanks for the reply. I might just stick it behind the drivers side for now and see how it goes. I used to have a 12inch alpine in my VT (sedan) and had the bass turned right down as it was far too loud for my liking. Also my car would rattle like a bitch.
    I thought about making a box but I did the maths and it will cost me more to build it than to buy one. Now im off to track down a reasonably priced 4 channel amp to run my Alpine splits in the front and the sub up my arse ;-)
  1. [WA] WTB: Alpine 6.5" type R
    By savage1987 in forum Swap / Wanted to Buy / Trade
    Last Post: 29-03-2009, 02:40 AM
  2. 12" Type S alpine sub
    By AndyVKSSA in forum Parts And Other Items For Sale
    Last Post: 06-01-2007, 09:18 AM
  3. FS:[QLD] Alpine V12 amp, Type S 12" & Box
    By knowledge_is_power in forum Parts And Other Items For Sale
    Last Post: 08-12-2006, 12:34 PM
  4. Alpine type R 12" sub
    By 5spdVN in forum Parts And Other Items For Sale
    Last Post: 09-12-2005, 06:46 AM
  5. What amp to use with 2 alpine type r 15"'s?
    By Stubby in forum Car Audio
    Last Post: 18-06-2005, 01:23 PM
