Results 1 to 7 of 7
Thread: help with sub + amp
    vy II exec
    May 2010
    WA
    Default help with sub + amp
    im getting a sub and amp for my vy
    i dont know anything about car audio but im thinking of getting this bad boy
    Ryda Car Audio - Fusion EN-AB1120 Active 12" Sub Enclosure($239.95)
    and putting it in myself
    does anyone have advice on installation or about this sub/amp combo
    cheers
    VZ Evec 05
    Jan 2010
    South Coast NSW
    mate unless you have an after market stereo or your stock headunit has been modded by Phreddy (ASR AUDIO) you wont be able to have a sub. stock headunit does not have an RCA output.
    and also dont waste your money on Encounter Fusion stuff....it is the cheapest stuff they sell and quality is very poor. Reactor is mid range and Powerplant is top of the line stuff. may not be the absolute best on the market but Fusion is definitely the best "bang for buck" brand
    benno9911's Avatar
    benno9911 is offline Donating Member
    03 VY S2 Exec
    Jan 2010
    Warrnambool
    yer i got that one in my vr goes all right wasn't that hard to hook up. comes with low and high output witch is handy and for the sound of it is not that good i have had mine for 5 months and it and the amp is on its way out. but time for an upgrade for me looking at 4 12" for my boot and i will not be going fusion
    Bumming lifts, saving up.....
    Mar 2009
    Cairns White Rock
    That amp has high level inputs, so you can use the signal from your rear speaker wire, then set the LPF on the amp accordingly.
    As far as how it is going to sound, it's a rather small sub setup for a car as large as a Commodore. If that's it, as far as your budget will allow, then for the money it is going to be comparible to basically anything offered by the rest of the mainstream suppliers.
    If it wasn't for your lack of knowledge, i'd be looking towards getting something from the used market, and fabricating your own enclosure.
    01' Vx Comm
    Apr 2010
    Gold Coast
    Quote Originally Posted by marcdon View Post
    You dont need RCA output.. you can buy a small converter that converts your rear speakers or front speakers into an RCA plugs.. which works perfectly..
    Ashes to ashes and dust to dust, if it weren't for Fords our tools would rust.
    Mar 2009
    Cairns White Rock
    Quote Originally Posted by wicksy View Post
    you dont need rca output.. You can buy a small converter that converts your rear speakers or front speakers into an rca plugs.. Which works perfectly..
    the amp has high level speaker line inputs
    vy II exec
    May 2010
    WA
    cheers for the help
    i'm gonna put it off until i get some more cash and probly get head unit + a better sub
Tags for this Thread
