Results 1 to 4 of 4
Thread: Runnin speaker wire to the back doors in VX Wagon.
    VX Berlina Wagon
    Oct 2007
    Default Runnin speaker wire to the back doors in VX Wagon.
    gday guys..i was installing my soundsystem yesterday in my VX Berlina wagon when i came across a problem, the front seatbelts are covering the spot where i need to get to so i can feed the wire through that rubber hose thing into the rear doors. if i unbolt the seatbelt, will that mess with any airbag sensors? if so, how do i feed wire to the door?
    VX Berlina Wagon
    Oct 2007
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    Im 99% sure you wont mess about with the airbag sensors by undoing the seatbelt bolt.
    Also, why dont you just use the stock wiring thats running into the doors? Unless your connecting these speakers to 200+wrms on each side theres no problem just using that wiring. You can access the speaker wires in the main loom under the sill panel (near the front seats) or if youre running these speakers off the head-unit just connect the wiring there.
    150db in a commodore =
    Tasmaniak's Avatar
    Tasmaniak is offline Not a valid input....
    car
    Apr 2005
    you DO NOT need to remove the seatbelt....you can if you want and you won't mess with anything but you are just wasting your time. On either side of the seatbelts is a service hole, if you pulll the grommet from the outside and then feed the wire through that service hole you will feel it poke through allowing you to grab it with your finger and pull it through the rest of the way you need too.
  1. How to run speaker wire through front doors?
    By sweefu in forum Car Audio
    Last Post: 29-08-2009, 04:37 PM
  2. Speaker wire
    By Deutscher in forum Car Audio
    Last Post: 14-08-2009, 01:39 PM
  3. Speaker Wire Help
    By JunyaVn in forum Car Audio
    Last Post: 09-05-2006, 02:59 PM
  4. VT speaker wire
    By mada in forum Car Audio
    Last Post: 18-01-2006, 09:54 AM
  5. Replies: 9
    Last Post: 29-06-2005, 05:49 AM
