Results 1 to 7 of 7
Thread: Power, Grounds and Remote wires for amps.
    VX Berlina Wagon
    Oct 2007
    Default Power, Grounds and Remote wires for amps.
    hey guys, installing my new sound system....the system consists of 2 splits in the front, 2 coaxes in the rear doors and a sub being powered by a monoblock and a 4channel....i am unsure how i need to run the power, grounds and my remote wires..i have a power distributer block and a fuse but im unsure on how to connect it all up. can anybody help me out??
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    Certainly can help you out.
    Power cable runs from the battery to the mounting location for the amps (boot i imagine). From there it connects to the distribution block, out of the distribution block is two cables (usually smaller than the main power cable) which connect to the + terminal of each amp.
    Ground cables connect to the - terminal of each amp and go to a solid section of metal on the car, the seatbelt bolt is a good location. Sand back the area to bare metal before attaching the cables.
    Remote cables connect to the blue / white wire coming out of your head-unit. These run to the amps and connect to the "REM" or "remote" input on the amp. You can just run one remote cable and split it into two cables near the amps or just "daisy chain" the remote wire from one amp to the other.
    Do you need to know about connecting the speakers / sub up to the amps?
    150db in a commodore =
    VX Berlina Wagon
    Oct 2007
    thanks mate, have already connected the speakers to the amps...do i need to run anything to the negative terminal of the battery? can i use the same gauge power cable on both sides of the power distributer? how far from the battery does the fuse have to be?
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    No you dont need to run anything from the negative terminal, you can use the same gauge power wire on the D.B. but usually a smaller gauge is whats provided in the kit (i.e. if its a 4AWG kit, it should come with a length of 8AWG cable for the amps).
    The fuse needs to be within 30cm of the battery terminal, its there to protect the cable in the event of a short.
    VX Berlina Wagon
    Oct 2007
    thanks alot mate....the kit didnt come with any smaller gauge, my friend was saying the same thing....my distributer has 2 inputs, will it be fine with just the 1?...also, will the power cable be fine without a grommet on the firewall?
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    Yeah it'll be fine with just one input.
    I would definitely be using a grommit for the firewall. If you run the cable through the unused clutch cable grommit (i assume your car is auto) then just cut a hole in this grommit and feed it through. Your asking for trouble having the cable rubbing against the metal of the firewall, its only a matter of time before the insulation wears through and causes a short.
    mawsy is offline giggity giggity
    VZ SSZ UTE
    May 2008
    QLD
    well said champ! make sure the earth is a good metal suface with no paint, most problems are avoided by having a good earth, i found out the hard way in my old ute haha and i know in the electricla worl outside of cars we try and run smaller cable out to the circuits from the board than what we ran into the board, the same should apply for cars
    How much wood could a wood chuck chuck, if a wood chuck could chuck wood?
  1. no power to amps
    By MAS_614 in forum Car Audio
    Last Post: 30-03-2010, 10:52 AM
  2. installed 2 amps but no power?
    By vscom88 in forum Electrical Wiring / Questions
    Last Post: 26-01-2010, 10:23 PM
  3. This Ones Got Me Stumped... No Power To Amps
    By sweefu in forum Car Audio
    Last Post: 16-01-2010, 03:26 PM
  4. Precision Power amps?
    By HCVP in forum Car Audio
    Last Post: 13-06-2009, 10:51 PM
  5. power window wires
    By joshsvs in forum Electrical Wiring / Questions
    Last Post: 16-03-2006, 11:17 AM
