Results 1 to 5 of 5
Thread: alpine type R 12' amp advice needed!
    VR Executive
    Feb 2010
    Default alpine type R 12' amp advice needed!
    i have an alpine 12' type R sub all ready to go but i need some advice on what amps to look at. atm ill just be running the sub with my stock VR speakers, well as far as i know they are stock. Ive been into Alberts and of course they directed me straight to a $700 amp. but i think that's a bit overboard. i also went into audiocom, told them what type of sub i have and they basically said they cant tell what amp i need just from a name, so that was no help. next plan is to take my sub in and get them to have a good look
    here are the sub specs:
    12" Dual Voice Coil Subwoofer
    1500W Peak, 500W RMS
    Power operation between 200-500W RMS
    Dual Voice Coil- Available in D4 (2 or 8 ohm operation) or D2 (1 or 4 ohm operation) [Select below]
    Kevlar reinforced pulp cone
    Santoprene rubber surround
    Cast aluminium frame with perimeter venting
    Transfer Plate, designed and Engineered in the USA
    Dual Progressive Oversized Nomex Spiders
    Dual Stacked Magnets
    Frequency response: 23-500 Hz
    Sensitivity: 85 dB
    Depth: 19.5cm
    im hoping for something under $500
    any advice is appreciated
    cheers
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    Yep we will need the model number of the sub as they come in dual 4 and dual 2 ohm configurations. This will help us suggest a suitable amp for your sub, you'll definitely be able to get something decent for under $500.
    If its a 4 ohm model - SWR1242D then the Alpine MRP-M500 is perfect, with a RRP of $499 im sure you could find it for around $400.
    Thats also if you want to stay with Alpine for the amp, heres a few other options that produce a similar amount of power:
    Kenwood KAC-9104D - 900wrms at 2 ohm - $349 at Ryda which is an excellent price.
    JL Audio G1700 - 700wrms at 2 ohm - $486 at Ryda.
    If its a 2 ohm model - SWR1222D then heres a few suggestions to suit:
    Once again the Kenwood KAC-9104D will be suitable, its stable at 1 ohm so it'll work with the dual 2 ohm version.
    Option Audio OAX801 - 820wrms at 1 ohm, Joe from Shopping Secure is a sponsor on here, so he may be able to give you a small discount.
    So as you can see theres a few options that will power that sub easily and for well under the $500 mark
    150db in a commodore =
    Bumming lifts, saving up.....
    Mar 2009
    Cairns White Rock
    I ran 2 of these sub's for a while, some time ago. I can tell you they will take a fair bit more than the rated 500 input in a sealed enclosure. Also, disregard the manafactuer's reccomendations for enclosure size's, anything less than 2cu ft per driver, will hinder their low fq abilities...
    VR Executive
    Feb 2010
    thanks for the quick replies, i think i might look into the Kenwood amp, seems like a good deal. plus being cheap i have more money for other stuff like a wiring kit :P
    CH Lancer
    Jul 2009
    Option Audio OAX801 is $310 including shipping btw if interested
    Joe Bellissimo
    Shopping Secure - Car Audio Specialists
    www.shoppingsecure.com.au
    MSN/Email: sales@shoppingsecure.com.au
  1. alpine type x subs
    By fatvsss in forum Car Audio
    Last Post: 09-03-2010, 06:55 PM
  2. Alpine type X set up
    By vz05 boar in forum Car Audio
    Last Post: 28-01-2010, 05:29 PM
  3. 6x9 Alpine Type R's or S?
    By Sambo in forum Car Audio
    Last Post: 10-03-2009, 12:07 PM
  4. Alpine type R
    By Dan_VX_Spac in forum Car Audio
    Last Post: 13-12-2008, 08:18 PM
  5. alpine type r
    By reggie_c2005 in forum Car Audio
    Last Post: 01-09-2008, 07:18 PM
Tags for this Thread
