Results 1 to 6 of 6
Thread: Where to put second amp
    VX Berlina S2 Gen 3 V8
    Feb 2010
    Echuca
    Default Where to put second amp
    I am in the middle of my installation. Got a few questions.
    I have an MB Quart RAB450 amp (4x50w guaranteed minimum power)
    Kenwood KAC-8401 amp 60Wx4 RMS/180Wx2, max power 640W
    Kenwood KAC-8101D amp 200Wx1 RMS @ 4ohms
    I am going to run my 12 inch Cadence UD 124-H SUB off the KAC-8101D and put the amp in the back of the wagon with the sub box (on either side) so that's no problem.
    But here it is. I have a set off Fusion splits in the front doors and stockies in the back doors at the moment. I was going to run the MB quart amp to the fusions bridged and the KAC-8401 to the rears. The problem is where do I put them? Under the passenger seat for the MB Quart, but where do I put the other amp?
    My other options are to
    a) forget the rear amp
    or b) use the MB Quart in 4 channel mode and run to the rear speakers
    Any ideas? I am not putting anything on the back of the rear seat as I still carry stuff in the back, hence my "tidy" install.
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    Forget the rear amp IMO.....you wont notice much difference anyway, plus you'll have less wiring issues
    150db in a commodore =
    Feb 2010
    Echuca
    Ok, so just run the rear speakers off the headunit?
    BTW I have 5.3m of 0 gauge power cable. 3m, 2.8m and 1m sections of 8 gauge cable. A fuse block for 0 gauge, and 1 for 8 gauge. And a dist block for 4 gauge.
    So what I was thinking is running the 0 gauge to the front seat, using the dist block and splitting the 8 gauge to the seat amp and running the other 8 gauge cable to the sub amp.
    Or running the 0 gauge to the sub amp, then running 8 from there back to the front seat for the speaker amp.
    Unsure on the best way.
    I don't need heaps of power, I just want better sound.
    Also would it be better to run the cable down the centre of the car, or down the side? In my previous cars I have ran it down one side of the car, but I have never put an amp under the seat before, only subs in boot.
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    Yep just run them off the h/u.
    I would use the 0awg for your monoblock, youve got 3m of 8awg cable so why not just run this straight from the battery the under the seat? That way you wont need to muck around with distribution blocl and running 8awg to your mono. You can get 4awg fork terminals for the Kenwood mono, just give the 0awg a "haircut" so it will fit into the 4awg terminal
    Heres the terminals:
    Overkill is almost always a good thing
    Feb 2010
    Echuca
    Thanks. I guess I was trying to make it more complicated then it needed to be, that is much easier. Cheers.
    BTW the pic doesn't work for me.
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    Yeah thats how i'd do it, no that pic isnt working now for me either.....oh well, im sure you know what a 4awg ring terminal looks like
