hey, was trying to figure out where to connect a remote wire for my amps using the stock headunit, so not sure where to connect it, but anyways, on the passenger side there is a black cable with no end, i spliced it open and it had a red and black cable inside, what is it? is it used for a mobile kit? can i use it for a remote wire for my amp?
if not can someone explain where to connect a remote wire, like the exact point, not just "to an accessory" coz i dont know where that is lol
thanks
richard
Tap into your cigarette lighter?
"Nonsense, this is the kind of coverings what we humans wear at this period of time. I'm quite sure of it."
See my ride here
these are the wire colours for the phone kit plug. should be able to use accessory wire off that.
Orange - 12V supply
Black/Green - Earth
Yellow - 12V Accessory supply
Yellow w/stripe - Radio mute signal
Blue w/stripe - Audio -
Blue - Audio +
VESPERS BLUE VZ Berlina LS1 (Calais conversion)
what if you just run from a constant 12v through a switch? would work just fine![]()
How much wood could a wood chuck chuck, if a wood chuck could chuck wood?
