Results 1 to 5 of 5
Thread: Advice Needed
    VZ Ute/VT Sedan
    Jun 2005
    Townsville QLD
    Default Advice Needed
    I have a VT Commodore currently using standard sound system. I also have a Kenwood MP3 Player KDC-MP4026 and a set of Clarion SRS1625 speakers which I pulled out my VN when it got written off as a result of a "not my fault" altercation with a Landcruiser with a (big) bull bar. I am going to replace the Double din standard head unit with the Kenwood and an Aerpro CD storage unit. Should I replace the in door speakers with the Clarion units or is it not worth the trouble?
    Mike S is offline Car Audio Pro
    Jul 2005
    Hi Burnie, sorry to hear about your VN, hope you got out of it ok.
    You should DEFINATLY change the door speakers, it will sound a million times better !!
    You should be able to do it yourself, if you have any problem getting the door trims off get back to us , someone will talk you through it.
    Mike
    Tasmaniak's Avatar
    Tasmaniak is offline Not a valid input....
    car
    Apr 2005
    *talks a lot*
    VT Executive S2
    Jun 2005
    Morayfield - QLD
    Post
    Does the VT have tweeters in the dash? Some do. Some don’t. depends on what year they were made I think. Personally, I don’t think the stock speakers sound all that bad. I had duel cone’s in mine (not splits) so I imagine that the splits would sound better. If you looking for more bass get yourself a big fat sub or run some 6x9’s in the rear shelf off an amp (2x100W rms or something) if your looking to save boot space.
    VZ Ute/VT Sedan
    Jun 2005
    Townsville QLD
    Thanks all-I will install the lot. Yes I believe the doors on VT are lots trickier than on the old VN
  1. advice needed
    By Tekka in forum The Pub
    Last Post: 02-02-2007, 12:13 AM
  2. Advice needed! (What to buy)
    By Trei in forum General
    Last Post: 01-02-2007, 01:20 AM
  3. HELP, advice needed?
    By wadeson88 in forum General
    Last Post: 29-01-2007, 06:56 PM
  4. Help Advice Needed!!!
    By scbh81 in forum The Pub
    Last Post: 03-11-2006, 11:06 AM
  5. advice for who needed
    By crazy for vl in forum VL Holden Commodore (1986 - 1988)
    Last Post: 21-07-2005, 05:42 PM
