Results 1 to 7 of 7
Thread: vt parcel shelf rattle
    VT commodore
    Feb 2010
    cobram
    Default vt parcel shelf rattle
    got some major parcel shelf rattle is expander foam the best solution for this or is there other better ways?
    calais_cruzin's Avatar
    calais_cruzin is offline Calais_Rattling....
    92 VP Calais 3.8
    May 2006
    Gold Coast
    i filled mine up with normal foam.
    just needs sumthink soft to lay agaist.
    U can stik stuff between the window n the shelf, ie stuffed toy
    ________________________________________
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    Find out what's rattling and put something between the objects.
    My shelf rattled against the glass, so I put something soft between the two surfaces.
    VYMAD's Avatar
    VYMAD is offline SILVERFOX
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    Expanda foam will most likely "expand" a hell of a lot more than you require it to, with possible disasterous results! I'd go with the normal foam, pull out the parcel shelf and fit the foam into every possible place you can that may be causing rattling. A lot of stuffing around, but if you take your time, you should get good results.
    VY Berlina V6 / R31 Skyline
    Dec 2008
    ..Dynamat?..
    Quote Originally Posted by xVisions View Post
    driving without a license at the moment, My vl has beaten every single car I've street raced!!
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    Quote Originally Posted by sweefu View Post
    ..Dynamat?..
    No, Dynamat is NOT for rattles.
    Dynamat is a deadener, it's used to deaden panels.
    VX 'S' S1
    Apr 2005
    South East,Victoria
    Remove the parcel shelf and you will see a couple of smallish sheets of sound deadener . They come adrift from the shelf and start to rattle .Also the tape that sticks the wire from the brake light to parcel shelf also comes unstuck . When i installed some 6x9s i used some underfelt and that fixed the prob .
  1. parcel shelf
    By VKCOMMO in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 12-10-2009, 10:59 PM
  2. [WA] vp parcel shelf
    By jamo25 in forum Swap / Wanted to Buy / Trade
    Last Post: 12-09-2009, 01:01 AM
  3. Ve Parcel shelf
    By bigfut in forum Car Audio
    Last Post: 17-05-2009, 04:07 PM
  4. Vz calais parcel shelf rattle
    By Hropic in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 20-09-2008, 10:27 PM
  5. like that parcel shelf rattle!!!!
    By ben_9876543 in forum The Pub
    Last Post: 26-05-2008, 01:33 AM
