Page 1 of 2 12 LastLast
Results 1 to 25 of 38
Thread: Dash Dims when sub kicks.
    VX Berlina Wagon
    Oct 2007
    Default Dash Dims when sub kicks.
    hey guys....just installed my new stereo....i had the car running and started playing some music, and noticed that everytime the sub kicked, all the lights on the dash would dim a fair amount......does this mean i have an electrical fault? or do i need to upgrade my alternator or something?
    TrikkBen's Avatar
    TrikkBen is offline Compulsive.
    BNR32
    Apr 2009
    SE, Vic
    It means the sub is drawing to much power from the car, You could install a Capacitor.
    There is no such thing as stupid questions, Only stupid people.
    Philthy's Avatar
    Philthy is offline That dent guy
    VS Berlina, XC AMS Project
    Aug 2005
    Upgrade your earths. There is a thread floating about somewhere that will show you how
    Search "big 3" or simply "earth upgrade"
    VX Berlina Wagon
    Oct 2007
    i was going to ground the negative battery terminal to the chassis.....but is this going to be a bare minimum fix?
    Philthy's Avatar
    Aug 2005
    Its a good start. Use at least 4g cable, sand back the paint, and lately I have been using "wire glue" from jaycar on my earths as well to seal them up
    VY Berlina V6 / R31 Skyline
    Dec 2008
    Plus ensure your amplifier earth is the same as philthy said, well sanded back etc. Make sure you power cable is up to the job too. If your amp terminal accepts 4awg - give it 4awg.
    My last stereo ran 1260wrms on stock altenator and battery with no dimming anywhere at all.
    Quote Originally Posted by xVisions View Post
    driving without a license at the moment, My vl has beaten every single car I've street raced!!
    Bumming lifts, saving up.....
    Mar 2009
    Cairns White Rock
    Quote Originally Posted by King_berald View Post
    If you gave us some more detail, such as a full list of the components you are using, then we would be more likely to be able to tell you what upgrades would benifit you the most.
    And no, a capacitor will not fix the issue.
    VX Berlina Wagon
    Oct 2007
    oh sorry....i got 6.5" type R splits in the front doors....6.5" typr R coaxs in the rear....and a 500watt rms type R sub....i have a 500watt monoblock and a 1320watt 4 channel...
    Dec 2008
    My last stereo ran 1260wrms on stock altenator and battery with no dimming anywhere at all. Have you checked all this stuff mate?
    VX Berlina Wagon
    Oct 2007
    i have sanded patches under the rear seat to bare metal then got a terminal with a copper washer and used a self taping screw into the body....is there any other ways that would be better?
    Dec 2008
    What are the model numbers of the amps and what power cables have you run/how are they distributed?
    Cheers.
    VX Berlina Wagon
    Oct 2007
    umm mrpf600...mrpm500....i bought a 4gauge sony wiring kit....and ive run the power cable straight from the battery up the side of the car to a distribution block under the back seat, which splits in 2 and goes to my amps in the back.
    Dec 2008
    Is the 4 guage kit split to 2x8guage wires? The 4 channel needs a 4gauage power cable all to itself. According to the specs the mono can run off an 8guage powe wire, though if you can fit it under the terminal 4guage is the way to go, considering it is putting out 500wrms.
    I'd say an upgrade in power wires is needed mate.
    savage1987's Avatar
    savage1987 is offline fail champion
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    I wasn't aware that undersized power wires could cause dimming..
    This would definitely be the problem in my VR if it is indeed the case
    Sam
    WTB: mulberry VN interior parts
  15. #15
    Dec 2008
    Not sure mate but i know it wouldnt be helping the situation, but with those amps you shouldnt get much dimming. Either way though - always make sure your power cables are up to the job!
  16. #16
    VX II Calais LS1
    Jan 2010
    Quote Originally Posted by HCVP View Post
    a power cap fixed the exact same problem in my car have a read of this...
    Car Audio Power Capacitors
    Quote Originally Posted by destiny View Post
    so im gonna need a supercharger? fck that ruined my dreams, oh well, it will b easyier to get a turbo then i dont have to pay for the boost.
  17. #17
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
  18. #18
    VX Berlina Wagon
    Oct 2007
    theres no 8gauge wire in my install...i got 4gauge going to the distributer...and two 4gauge wires coming out...
  19. #19
    VX Berlina Wagon
    Oct 2007
  20. #20
    VE Calais-V 6.0L
    Aug 2005
    Hastings
  21. #21
    Mar 2009
    Cairns White Rock
    Quote Originally Posted by bandit10 View Post
    If i wrote a page long article about why you wouldn't buy one, then posted a link, would that be sufficient to change you mind?
  22. #22
    VX II Calais LS1
    Jan 2010
    if your page long article made my lights dim again then maybe... but seen as the power cap fixed it then no lol
  23. #23
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    Stop saying "power cap" it's gay. It's simply a capacitor.
    It should be one of the last things to try when diagnosing electrical issues. First things to do is to make sure the wiring throughout is adequate size, including grounding from battery to chassis and battery to engine block. The grounds should all be checked to ensure there is good contact to bare metal.
  24. #24
    Dec 2008
    Quote Originally Posted by StoneX View Post
    StoneX is right here, everyone quick! Listen to him!
  25. #25
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    HAHA "Power Cap". Hey maybe its a capacitor that generates its own power, that would be awesome.
    I remember someone telling me that a 1 farad cap holds about as much power as a AA Battery, any thoughts?
    Ronald Reagan (1986)
  1. T700 kicks in second gear when taking off
    By Richo2 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-05-2010, 03:48 PM
  2. VS Kicks Over, Sucking Noise, then dies
    By unionoz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-07-2009, 08:06 PM
  3. VN starting problems, kicks over but wont run
    By Bz Kn33z in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-06-2008, 04:39 PM
  4. VS Calais V6 trans slipping when under throttle and kicks back
    By goldvnaero in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-06-2008, 10:37 AM
  5. Headlights/console dims at not the best of times
    By newo in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-07-2005, 05:56 PM
