Results 1 to 4 of 4
Thread: Problem!!! Vt door speakers
    VT II SS LS1 6Spd
    Mar 2008
    Default Problem!!! Vt door speakers
    Today I bought 4 6" Alpine type R's for the doors in my VT and they wont fit in either the stock housings or the several that came with it.
    Do I need to buy housings for it to fit or do I have to make up a custom job?
    Cheers for any help.
    SweetWagon's Avatar
    SweetWagon is offline booosted
    VS Berlina Wagon Supercharged & VU SS Ute
    Jan 2006
    Springwood NSW
    I have fitted Type R's to a VT, not a direct fit, but you need to trim the pods to make them fit.
    Power is measured in DECIBEL
    VesperZ's Avatar
    VesperZ is offline 2005 Holden VZ Berlina
    VZ Berlina
    Jul 2009
    Sydney, NSW
    Also use the supplied spacers as the speaker is quite deep and will hit your door. Alpine Type R speakers are all 6.5", the stock VT speakers are 6", that's why they seem as if they won't fit. Basically screw your spacers to the existing pods, you'll need to cut the back of the pod to allow for the depth and they'll fit straight in.
    "Nonsense, this is the kind of coverings what we humans wear at this period of time. I'm quite sure of it."
    See my ride here
    VX lumina
    Jul 2008
    SE Melb
    the type r's also move alot of air... if you can spend some extra money and get some dynamat/roadkill and like the door skin with about 20cm*20cm and it will make it sound deeper and cleaner.
    just a simple trim on the standard pods should fit them.. but ive never fitted r's into a vx/vt so like mentioned above you might need to space them..
  1. speakers in a vg door
    By B_unit in forum ASR Audio & Electronics
    Last Post: 25-08-2009, 10:59 PM
  2. Replies: 2
    Last Post: 04-09-2008, 08:18 PM
  3. VT door speakers
    By totality in forum Car Audio
    Last Post: 29-05-2006, 01:17 AM
  4. door speakers
    By GH05T in forum VL Holden Commodore (1986 - 1988)
    Last Post: 24-11-2005, 09:29 PM
  5. VT Door Speakers
    By vxsenator in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-07-2005, 05:02 PM
