Results 1 to 11 of 11
Thread: Problems installing my head unit!
    VT Calais
    Jun 2010
    Exclamation Problems installing my head unit!
    hey every1 Where can i get a good adaptor or wiring harness for tha head unit of a VT from? I got 1 from supercheap but it was shit i couldnt get any sound. I finally realized that some of tha wires were in tha wrong place, tha blue was going to nothing. I pulled it out n changed it to tha aerial wire but still no sound. Any help would be appreciated.
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    Using the VK-VZ wiring colours thread, here is what each wire should connect to:
    Red - Yellow
    Yellow - Orange/White
    Black - Black/White
    Blue - Yellow/Red
    White - Tan
    White w/black stripe - Grey
    Grey - Light/Green
    Grey w/black stripe - Dark/Green
    Green - Brown/Black
    Green w/black stripe - Yellow/Blue
    Purple - Blue/Orange
    Purple w/black stripe - Blue/Black
    Check the wire colour / location in plug of each wire, then follow it through to the adapter and see if it matches up with the colours above.
    150db in a commodore =
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    If you wired it wrong first, then you could have killed the amp in the head unit.
    VT Calais
    Jun 2010
    VT Calais
    Jun 2010
    Quote Originally Posted by holdenboy View Post
    Red - Yellow
    Black - Black/White
    Blue - Yellow/Red
    White - Tan
    Grey - Light/Green
    Green - Brown/Black
    Thanx bro i'll give it another go and make sure its like this, i think it was just tha blue in tha wrong place.
    VT Calais
    Jun 2010
    still have no sound. I was looking on tha net 4 wiring harnesses and all r tha same for VT. Tha blue is ment to be next to tha black right? All tha harnesses have tha blue on tha oppisite side wtf? On tha plug in my car there is no wire going to where that blue wire is. Has any1 come across this b4?
    madnuts's Avatar
    madnuts is offline custom audio installer
    vz 3.6
    Mar 2009
    Penrith
    there should be a sticker on your old head unit telling you what wires go where
    where are u from if your in sydney near penrith i could help u
    VT Calais
    Jun 2010
    ^^ nahh QLD man. I pulled all tha wires out of tha harness and put tha head unit wires straight into tha plug but now i found a blown fuse in tha blue wire so i will buy 1 2morrow and see if it works this time. I have all tha wires in tha right places, if it dosnt work it must be tha head unit. When i pulled it out of my old car it was fine? so i dont know.
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    The blue wire is for the power antenna, if its disconnected then it wont affect the sound output. Only radio reception as the antenna dosent go up.
    Sounds to me like a blown amp inside the head-unit.
    VT Calais
    Jun 2010
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    Maybe look into getting the new unit fitted by a pro, alot of shops wont warrant a blown internal amp if youve installed it yourself. All i takes is one of the speaker wires to touch metal (earth) or touch each other while the unit is on.
  1. installing head unit in vy
    By lok in forum Car Audio
    Last Post: 03-10-2008, 07:36 PM
  2. Need help installing head unit into VS
    By Burkey69 in forum Car Audio
    Last Post: 28-03-2008, 07:55 PM
  3. Installing head unit....
    By CLE in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-10-2005, 06:48 PM
  4. Installing head unit
    By Muttley in forum Car Audio
    Last Post: 11-09-2005, 03:21 PM
  5. Installing a New head unit into a VT...
    By DintD in forum Car Audio
    Last Post: 01-09-2005, 03:32 PM
